Question about Royal VF1012mx Shredder
There is paper stuck in the shredder how do I get it out. I have tried the reverse and forward several times.
  • 313 Answers
IF YOU GET A PIECE OF THICK PAPER OR AN ENVELOPE AND FEDD THAT THROUGH IT SHOULD CLEAR IT FOR YOU YOU COULD OPEN THE DOOR AND FEED THE PAPER UP FROM THE BOTTOM BY CHEATING THE DOOOR SWITCH BY PUTTING A PIECE OF PAPER IN THE SLOT FOR THE ACTUATOR THAT WILL LET THE MOTOR RUN FOR YOU...hOPE THIS HELPS a
Posted on Jul 30, 2009
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Shredder goes 1/3 and stops has to be reversed the forward also paper comes out punched but unshredded
its the combination of plastic parts in the shredding device . the plastic tongs part craks off then the metal binds . paper builds up in that area .
its unlikely you can fix it .
youll put ur eye out trying.
Aug 03, 2014 | Industrial Paper Shredders Office...
Omnitech only runs in reverse
In the middle of feed opening there is a sensor which in your case will be stuck. Try clear it using tweezers. Failing that soak the blockage up excessively with WD-40 as it will loosen and soften stuck paper leave it for 10-15 minutes, repeat 2-3 times. Then power on the unit and it should be good as new! Good luck
Jul 19, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
There is paper stuck in the shredder. I've tried shredder oil and a tweezer.
Alternate reverse and forward several times. Graphite powder or pencil lead along the engaged gear teeth may help. There is probably a "wad of paper" underneath where you can't see it. Be brave and take the shred head apart - pay careful attention so you'll know how to put it back together.
Sep 02, 2010 | Royal 150MX Cross-Cut Shredder
Shreder works in reverse but not in forward.
Check in opening and see if paper switch is stuck.
Dec 01, 2009 | Adler Royal HT500X Shredder
The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
Aug 10, 2009 | Fellowes DM8C Cross-Cut Shredder
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Apr 13, 2009 | HSM 225.2hs Shredder
Shredder problem
May I respectfully suggest that you do not attempt any repairs on anything that creates a "blue fuzz" of electricity.It is not worth the risk. I am a retired electrical engineer and over the years have developed a healthy respect for faulty electrical devices. Sparks anywhere near paper is a disaster waiting to happen
good luck
Loringh
Nov 01, 2008 | Office Equipment & Supplies
Royal VF1012mx Shredder Logo
332 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
