ERROR OBSERVED E000225-0001 SO WHAT TO DO NOW???? SO MANY TIMES SHUTDOWNED THE PRINTER STILL REMAINS SAME.
SOURCE: error code 5100 on canon pixma 6600d
Hi You can Try
Error Code 5100
ok try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
SOURCE: I HAVE AN IR3225 AND
this is error code for abnormally high temperature in fixing unit.
If there isn't anything wrong with the fixing heater or thermistors you can try to clear the error code in service mode.
Procedure:
While the copier is showing error or in ready to copy mode
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Now on touch screen choose: COPIER>FUNCTION>CLEAR>ERR
Turn the copier off and back on.
That should do the trick.
If there is problem in heather or if the error occures again after few copies made, then you need to replace fixing film unit.
Hope that helps!
SOURCE: error code 6000 canon pixma mg8120 printer when trying to priint wirelessly
Hello and Welcome to FixYa!
Error 6000 actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
To solve this problem:
Check the timing disk film or Check the feed roller if is there any foreign body, remove it softly
Timing disk film is located at the left side of the printer
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
SOURCE: I have a Canon Ir3225 copier and on its screen reads error E000000-0001. How do I fix this problem.
Hi,You have to reset the error in service mode . To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
