Need to reset wast ink full error .Press the resume button power on printer after 3 Seccond holding press 3 times.
Tried this. Thanks but not solving the problem.
Press the power button & resume button both at a times on printer power 3 Seccond hold relaise the power button press 3 times resume button your printer must be reset.
Where u from?
Please see it youtube
Procedures to solve the 5B00 error message on canon printers:
First procedure:
This first tutorial will show you how to set your printer back to its original factory settings, so you won’t be working on the ink pad problems directly but on the printer as a whole. This restoring procedure will act on all the issues that may be found in your particular canon printer model, including this full ink pad situation.
You will need to turn your printer off and key it this way, unless we tell you the opposite. Mainly, you’ll be working with the stop/reset button on it to execute this solution.
This first procedure is mostly used on regular, non-multifunction printers. However, the buttons referred to in this post can be found on both printer types, with or without Inkjet systems. After you’ve completed this restoring method, your printer’s name will now have the words “copy 1” attached to it in your computer. If you want to learn how to install a default printer on your computer, please read this post.
Step #1:
First, turn your canon printer off.
Step #2:
Now, press and hold the stop/reset button down. It should look like this on your printer:
Step #3:
While holding the stop/reset down, press the on/off button on the printer. This will turn the printer on and off again.
Step #4:
Let go of the stop/reset button and press it again two (2) times in a row, with light, tapping motions. Please remember to keep the on/off button pressed while doing this.
Step #5:
Let go of all the keys you were pressing down and wait until rest appears on your screen.
Step #6:
Touch the stop/reset button again for five (5) more consecutive times and, finally, press the on/off button two (2) times very quickly.
Thank you. Sorted
The ink absorber is basically a sponge that absorbs extra unwanted ink during the print process. When it can no longer hold anymore it shows this error. Replacing this is about the same as changing the ink carts for difficulty. You can find the proper one in your manual near the back under supplies and these can be bought at most stores that stock a good amount of printer supplies. You just open the access panel pull out the old and insert new one. The printer will then recognize it is new and will clear your error.
