Question about Bunn 10 Cup Home Coffee Brewer
Water coming out from underneath bottom of unit
I am losing 1/2 pot of clear water every time I put water in to make coffee or just water for tea. I have emptyed the whole thing and turned over and found nothing only screws that have rusted from the water leaking through. is there a fix or do we need to replace?
  • 20 Answers
If this is one of those units with the leaver that starts brewing when you close the fill lid, I have the fix. What has happened is that the "tank" that holds the just added water has deteriated due to heat from the stailess steel tank that hold the hot brewing water. This tank remains hot as long as the side switch is in the "on" position. You will have to remove the (3) screws that you can see from the top of the coffee maker. (2) are under the lid where you fill water. Remove the top of unit. You will find the lever in this "tank". You will need to remove the lever to access the fitting that screw into the stainless steel tank. This is the area that has deteriated from the heat. You will also need to remove (2) screws to be able to remove this "tank" for repair. After you clean the area where the "fitting" was removers from the top of the stailess steel tank. Apply a bead of RTV silicone around this area. This can be found in automotive stores. The RTV will form a seal around this deteriated area. IMPORTANT Make sure you don;t put to much RTV on parts. You don;t want to interfere with the seal on the leaver. Replace the "tank" along with the washer & fitting. Replace the (2) screws also. Replace the leaver. Replace the top cover with the (3) screws. Let unit sit overnight to allow RTV to set. I have done this fix twice. 3 years apart. I have not been able to find this part to purchase sepratlly. I can't see paying $85 for a refurbished unit.
Posted on Aug 07, 2009
I had similar problem with unit leaking from bottom . Leak is actually inside the fill tank on top. Mine is not lever activated. I removed three screws from tank top, lifted out the cover then unscrewed the tank to heater orfice. this is a brass fitting which can be removed using a table knife handle as an oversize screwdriver. The seal under the fitting has failed. By inserting an o ring under the fitting and reassembling the unit, the leaf has been repaired. o ring size is approximately 1 & 1/4 inches in dia. you can find at local hardware.
Posted on Sep 15, 2009
    Problem Solver:
  • 7 Answers
See to it that there is no leak,check it out.
Posted on Jul 30, 2009
Brand new! Cleaned it out with vinegar initially, poured in and turned it on. Still waiting, nothing is coming out at all. What's the problem?
LOL add another pot of water it has a storage tank of 1 pot ..it might take several pots to get all the vinegar out .
Dec 22, 2015 | Bunn O-MATIC NHS 10-Cup Professional Home...
Is it difficult to make Turkish coffee?
it doesn't really matter what bean you use to make Turkish coffee, what really matters is the pot that you make it in. An Ibrik is a traditional Turkish coffee pot which you can fill two thirds full with water. Add sugar and a heaped teaspoon of coffee. The coffee creates a seal at the narrow top. As you bring it to the boil the coffee with foam. You should let it foam three times before pouring into small cups. Let the grounds settle to the bottom of the cup before you drink it and don't stir it just before drinking.
Feb 27, 2013 | Home
How do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Feb 27, 2013 | Home
How do you brew a pot of coffee? Someone gave us a machine for our wedding and it just sits on the kitchen counter doing nothing.
I'm assuming you've got a coffee filter pot as this is the most common kind (especially as wedding gifts).
1. Boil the water.
2. Put the filter (should come with the pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee per 6 oz of water.
4. Pour some of the hot water over the coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
Feb 25, 2013 | Home
How do I use vinegar to clean my coffee pot? I heard it was a good method but have no idea what to do with it.
For a 12 cup coffee maker. Fill the coffee pot (the part that holds the water) with 6 cups of vinegar and then top up with water until you reach the line. Now turn it on as if you were making regular coffee. Once the hot vinegar has come through, pour it into the water cavity and run the cycle again.
Now you can tip the vinegar out and clean out the coffee pot with soapy water. Run another cycle but with plain water this time and after that you should be able to use your machine without any leftover residue from the vinegar.
Feb 25, 2013 | Home
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Bunn 10 Cup Home Coffee Brewer Logo
415 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
