Question about Jeep 2003 Liberty RBQ AM/FM Radio w/ 6-Disc Integral CD Changer
When i press the button to change from am to fm on the radio, the fm channel won't play. i can't only get am. 2002 jeep liberty
  • 52 Answers
I hate to be the bearer of bad news,but your radio is dead. I have replaced a few stock chrysler radios for that same reason. You don't have to go to the dealer and spend a ton of money to replace it. You can go to Wal Mart, buy a nice unit for a couple hundered bucks and a fit kit for $25.00 and be rock and rolling again. You could even check the local audio stores for installs if you don't do those jobs yourself. If you want a stock radio, check the dealer for cost, then check ebay. Good luck and if you want to be sure the radio is dead, pull the radio fuse, wait a few minutes so that it can reset, put the fuse back in. Then see if you have fm again. Sorry, but I don't think this will solve it.
Posted on Jul 31, 2009
I have a 2008 Jeep Liberty.The radio will not come in at all.No matter what channel I try,it comes in static
You have lost the antenna. It either fell out(seen this) or the receiver in the radio is dead.
Feb 22, 2015 | 2008 Jeep Liberty
How to play raido
hi,
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
ok
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
The radio in my 2002 Jeep Liberty re-starts every time the minute on the radio changes. Also, the CD player re-starts, so every minute it starts at the beginning of the CD. The sound turns off...
is it a factory radio??? if it aftermarket radio could be loose conection on one of wires but sounds more like the radio has a short inside the radio it self you probley have to replace the radio
Mar 12, 2010 | 2002 Jeep Liberty
Jeep rb3 radio not working
i have a problem with myn radio rb3 mijn display he desnt respond but mijn radio works
Sep 07, 2009 | Jeep Liberty RB4 Navigation, AM/FM, CD,...
CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Jul 20, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
I have a jeep liberty that just had a new battery put in and now the cd changer won't work. any suggestions
Alternately, try opening the CD changer door, ejecting the CD carrier and look for a small reset button below the opening. Press this with the tip of a pen and hold it for 10 seconds, then turn the radio/CD on again.
May 19, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
Jammed CD
Hello, I see your post is a few months old. If you still need help or a solution for this problem please feel free to contact me at rcruz@radiomedics.com
The loss of power to the unit should not have affected the CD player. It will re-sync upon powering back on but that is normal.
Regards,
Robert Cruz
1-877-4-RADIO-MD
Apr 19, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
I need to know how to get it on radio and change channels
hi there
if there is a source button press it till radio display is in screen if you press the source button it will switch from CD - tape - am/FM
to select the channels after this is done press left or right
hope i was able to help
Feb 16, 2009 | Pioneer KEH-P2030 Cassette Player
2004 Jeep Liberty CD Problem
Sometimes if you shut off the vehicle, then continually press the eject button, while you start it, and continue to press the button, until the radio is on for a minute, it'll work. Other than that, Sorry. Best wishes to you.
Jan 21, 2009 | 2004 Jeep Liberty
Car Audio & Video Logo
220 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
