Question about Frigidaire GLGQ2152ES Gas Dryer
Frigidaire FSE446RHS2 electric dryer makes bumping noise when drying. Opened the top, belt is ok.
Rear bearing and drum coupler needs to be replaced
bearing kit part #WC5303281153 is available online from many parts stores. You may want to replace the belt at the same time while you have the unit apart. Also inspect the front upper drum felt if it is worn replace it. The whole repair time for me was about 45 minutes dryer now runs like new.
Posted on Dec 18, 2009
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Drum makes scraping and bumping sound with out
the roller of the belt tensioner has a bad bearing which will cause the roller to burn up riding on the belt giving it a flat spot creating your horrifing noise
Feb 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My model # gler341cco electric dryer is making a
The only way to know for sure what is going on is to inspect the innards. I have assembled some photos to assist you: HERE
Jan 15, 2010 | Frigidaire GLER341A Electric Dryer
My dryer started making a bumping noise when it
Your slides are worn and when you put clothes in the metal tub is now getting tracktion/ making metal to metal contact when it shouldn't and overloading the electric/belt drive. There is a kit to fix the problem but the dryer will need disassebled to put it in. At this time it would also be adviseable to replace the belt and tub bearing as well.
Sep 22, 2009 | Kenmore 65924 Electric Dryer
I can't find the thermal fuse on a fse446rhs2 electric model
Location is inside the cabinet on the back wall. Upper right hand corner by where the terminal block is. Mounts by 2 screws. Part number 134120900 .
Sep 15, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer getting hot
Dryers overheating is usually caused by a venting problem, but it sounds like you have the bases covered on that. I would look at a faulty high limit thermostat. It can be checked with an ohm meter to see if it is faulty. Hope this helped and best wishes.
Jul 29, 2009 | Dryers
Frigidaire stackable dryer fse446rhs2 makes a bumping noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfghjhd
Nov 08, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire GLGQ2152ES Gas Dryer Logo
219 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
