Possible child safety lock.
Is the light on under the temp and spin buttons?If so,push those two buttons at the same time and hold till unlock
Also in wash cycle where water is still in the machine,the door will be locked and must first be shut off then turned back on and choose rinse and spin then start to get the water out of the machine.It should unlock after completion.
The manual for this machine is here:
https://resource.electrolux.com.au/Public/File/?Id=27616
SOURCE: Door won't open
My Zanussi has an outlet filter that is accessible by a little door at the front. It gets clogged if not cleaned for a month or two. Then the machine can't drain and the door won't open. Removing and cleaning the filter should correct the problem. You'll need some sort of container to catch the water that will pour out after you remove the filter.
SOURCE: Door locked
Rather than taking the top off the machine and fiddling around to find the catch as guest suggests, I got it to open with some strong string. I took a fairly long piece and threaded it into the groove where the door joins the metal front of the machine, on the catch side of the door. Then pull both ends of the string very hard to the left (you may want to wear gloves to protect your hands). Pull hard and move the string up and down until the door opens. Worked for me.
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
