Question about Kitchen Appliances - Others
Remington foot spa model F7027 - the water churns, but none of the attachments, eg. pumice or brushes seem to work.
4 Suggested Answers
  • 50 Answers
SOURCE: Instructions Needed
google the name of the spa on the internet you should be able to download the instruction that way. hope this helps :)
Posted on Sep 16, 2008
  • 4088 Answers
SOURCE: where can I find brushes for the remington model
Remington saw has gone out of business, and finding parts can be a hit or miss experience. Motor brushes in particular are quite rare, so you need to be resourceful in finding a similar brush used in other small tools. Visit a small tool repair shop or check with Ace Hardware (our local store has a whole display box of various sized brushes). If you do find something, buy more because these saws seem to eat brushes for lunch! Good luck!
Posted on Jun 08, 2010
  • 3698 Answers
SOURCE: Do not know which attachment to use to apply
http://www.ehow.com/facts_7196163_spin-spa-brush-user_s-guide.html
Posted on Jul 13, 2014
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Remington foot spa model F7028 instructions
While there is a lot of interest in this foot fixer..Mine is the acupressure model with 3 attachments. F7020
It is probably 13 years old.
For the lack of a manual, I can tell you what I've learned through trial and error.
- The heat setting does not burn you, but maintains the temperature you put in. Good for diabetics.
- The fill line , well it doesn't have one..just under half of the foot tub covers the feet and does not allow too much splashing as you use the rollers.
- The settings, heat.vibration.bubbles.foot massage all under the knob
- Cleaning.. use soapy water and sponge bathe it. as with any machine of this type avoid submerging completely. If you do submerge it accidentally it MUST be thoroughly dried before next use.
note: if you are a manual reader like me, the Clairol m o d e l fb2 7R has similar features and a good manual to boot.
Jan 23, 2013 | Health & Beauty
Have a Remington Electric Pole Saw Model 075081 looking for Brushes only for it, or the whole Field assemply part #075837 if I have too.
Remington Saws have discontinued operations, and any available parts for the saws require diligent searching on the web. These saws seem to eat motor brushes for lunch, and nearly every owner is looking for brushes as well. Your best bet is to try finding a similar brush from a different tool that might fit. Look to any power tool repair facility for whatever help you can get. A small company making replacement brushes would seem to be a lucrative enterprise. Good luck!
Dec 30, 2010 | Remington Electric Pole Saw
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
I have a Remington razor DA307. What is the best way to clean it? Can I run water over it? Thanks. Frank Fflynn001@att.net
The DA307 shaver is NOT washable. Exposure to water will damage shaver and possible expose you to electrical shock. Simply brush the cutter blade and shaver head area with the brush that came with the shaver. If you need a brush, you can find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-accessories/remington/remington-classic-style-shaver-cleaning-brushes-2-brushes-p-190.html
Sep 04, 2010 | Remington Health & Beauty
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
Where can I find brushes for the remington model
Jun 07, 2010 | Remington Electric Chain Saw
Chainsaw won't start
These saws seem to have chronic motor brush problems, and because Remington saws has gone out of business, parts are nearly impossible to find. If you have a broken brush, you may be able to substitute one from a drill or other light tool. Good luck!
May 20, 2010 | Remington 16" Electric Chain Saw
Kitchen Appliances - Others Logo
296 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
