Question about Coffee Makers & Espresso Machines
Machine stays in decalcify program though I did decalcify. Tirned off and back on, now says it needs to be decalified. Saeco Vienna Machine
Your water may be quite hard... so I did also this decalcification process through several times and I gave up, no I am just decalcifying it after couple of weeks with usual decalcifying liquid and it works fine. Probably the scale detector is not working properly.
Posted on Aug 26, 2009
  • 2,039 Answers
Is it a digital
Posted on Jul 31, 2009
What is the proper method to descale?
Yes, you should empty the bean hopper and put the solution in the tank and run it through.
Nov 09, 2007 | Saeco Vienna De Luxe Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
How can I descale my Saeco Vienna without beans in the hopper?
Hi
Never run descaling solution through the brew unit. You should never descale the machine hot either.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your type of machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles) .
4. Remove water tank and rinse it with fresh water.
5. Refill the water tank with fresh water and place it back on the machine.
6. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set. Done, refill your tank and run some water, and you are ready to go.
Dec 02, 2010 | Saeco Vienna Deluxe 708461030122DE
Steam function SAECO Vienna Exclusive not works
Check the thermostat on the steam boiler, that could have tripped, or the element on there could be damaged.
Jan 23, 2010 | Saeco Vienna De Luxe Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Decalcify
im not a saeco folks but i buy those machine on ebay and repair them decalcify ready to used mean its ready for you to put descaling product in machine and you press on it will start the descaling sequence if you dont whant to descale i sujject you do it if not go in our menu and push botton untill you see descaling finish or done thanks pierre p.s taking about descaling my machine vienna told me this morning time to descale it comme about every 3 months let me now i know those machine good
Jan 10, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Vienna is full of beans but the bean light stays on
the sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Nov 28, 2008 | Saeco Vienna De Luxe Espresso Machine
DECALCIFIER
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit www.CeriniCoffee.com
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco Vienna Super Automatic and for some reason it is no longer making steam. It starts to and then it stops.
If you open the steam knob, can you make a full cup of water or just a half?
How often have you decalcify the machine?
If it is long time then do a descale to make sure there not is calcium in your system.
Jul 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
1,121 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
