Question about Kenmore 6000 Wall/Window Air Conditioner
Moved a/c to another window and wont work
I removed a/c from one window and when I installed in another, the ground fault on the end of the cord keeps tripping, and will not power up the unit
  • 560 Answers
Check your outlet wiring. The polarized outlet has a narrow slot and a wide slot, and a ground hole, of course. Anyways, the narrow slot should be hot. If you put a voltage tester lead into the narrow slot, and the other lead into the grounding hole, you should read line voltage if the grounding hole is grounded properly. If you test the wide slot to ground and get line voltage, you have reversed polarity and must swap (reverse) the lead wires in the outlet to correct the problem.
Posted on Jul 31, 2009
When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Apr 03, 2015 | Heating & Cooling
Plug on window ac wontreset
You are referring to the "GFCI" on the cord?
If it won't reset, then most likely the apparatus on the cord, the GFCI, is doing its job?!!
It is sensing a ground short.
Need a professional to look at it.
Nov 14, 2014 | Video Game Consoles & Games
Kill switch wont work and 5 amp fuses keep blowing?
If by "Kill Switch" you mean automatic circuit breaker, it depends on its rated or adjusted breaking limit, but if it is a Ground Fault CB it is disconnecting at ground fault, not at overload.
Jun 01, 2010 | Gb Electrical 1 30 Amp Ground Fault...
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Jul 11, 2009 | Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM...
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Apr 05, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 6000 Wall/Window Air Conditioner Logo
102 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
