Lan only showing 10mbps
Im using the nvidia onboard lan with the asus pn5-d but it only ever shows me 10mbps when it is a 1000mbps
    Problem Solver:
  • 8 Answers
What is the speed of your network switch or router? If your computer is hooked to a 10 MBPS switch, that is all the speed you will get. My only other suggestion would be to look in the motherboard BIOS and see if there is a setting that affects the onboard lan speed.
Posted on Jul 30, 2009
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
My connection through my 2wire pc port phoneline is extremely slow, the internet is very laggy, yet all the computers connected directly to the router through ethernet cables are very fast
This is because the adapter is ONLY 10Mbps you need a higher one 100Mbps or even 1000Mbps... That adapter is too old to be used on a high speed network, replace it with a faster one.
Mar 06, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
P4B266-LA motherboard, with intergrated ethernet, not working how can i trouble shoot, i found some usb drivers for my modem and im only connected at 10Mbps instead of 100.
Hello!
It is so a litlle informacion, but I will try .
First step, you must see in bios,does the lan is enabled.
In some case, if lan is enabled, they can be a bad, if thunder.
If it so bay PCI network adpter, and you can solve you trouble.
In same case viruses can make a problem, and you must reinstall you system.
Also try to find drivers for you network adapter, on asus page, you search yours motherboard.
Nov 02, 2009 | ASUS M2N-X - Motherboard - ATX - nForce...
Cannot get the onboard gigabit lan to work?
You need the chipset drivers for the motherboard, to get the onboard ethernet adapter to work. Try this link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
If the link doesn't work, go to ASUS address, select the download option, then in the pull down menus, select:
> Motherboards
> AM/AM+
> M2NBP-VM CSM
You'll be prompted for your OS, so pick the correct one, then you'll be at the download page for all your drivers - Chipset, sound, graphics, etc.
Cheers
Nov 13, 2008 | ASUS M2NBP-VM CSM Motherboard
Nvidia chipset for A8N-E rev 1005
I once have a installer of Nvidia but I dont know where I place it. If ever I find it, I`ll tell you.
Oct 17, 2008 | ASUS A8N-E Motherboard
Ethernet LAN
That is a network card that has the abililty to automatically adjust it's speed between the old standard of 10MBps network systems all they way to the current 1000MBps, (1Gigabit LAN) network speed. And RJ45 is just a typ of connector that all network cabling uses. It's kind of a double-wide version of a phone plug.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Drivers
The onboard Network card is based on the nVidia nForce 4 chipset that is also the standard Motherboard Chipset. This can be downloaded from the Asus Website.
Are you having any difficulty with the Onboard LAN or is this just an issue of getting the driver for the LAN card installation?
Apr 22, 2008 | ASUS A8N-E Motherboard
Problem with the LAN Ethernet NVIDIA
right click on taskbar network icon and click disable
Mar 13, 2008 | ASUS P5N-E SLI Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
