Question about Polaroid i835 Digital Camera
Card Protected on Polaroid i835
I have a similar issue. SD Card is fine as I have used the memory card in another camera of different make.
  • 300 Answers
It's probably a broken switch inside the camera memory card readed. The memory card readers in cameras have a small switch that detects if the SD card LOCK switch is on. This is a hardware problem, you should give it for a repair - it's not a hard repair - I usually cut off the switch and put a wire so the camera allways thinks that the card is not locked.
Hope this helps!
Tom
Posted on Jul 30, 2009
Camera says card protected
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 11, 2012 | Polaroid i835 Digital Camera
Tells me card protected, card is not locked work fine in my computer
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 15, 2011 | Polaroid i835 Digital Camera
My Camera Wont Let Me Take Pictures It Says Card Protected What Can I Do?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 21, 2010 | Polaroid i835 Digital Camera
Polaroid i 835 says card protected what does that mean?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2010 | Polaroid i835 Digital Camera
Cant use SD card in camera It say the SD card isprotected What should I do
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sep 01, 2010 | Polaroid i835 Digital Camera
Card protected
SD and SDHC cards have a slide switch along one edge. The switch needs to be closest to the contacts to unprotect the card. If the switch is already there, slide it fully the other way and then back. If this doesn't work, try a different card. If that doesn't work, there may be something wrong with the sensing mechanism within the camera.
Jan 14, 2010 | Polaroid i835 Digital Camera
I have a Optima SD 8GB memory card for my camera and when I put it in it says "card not supported" "card not Protected" what can I do?
Sounds like your camera does not support SDHC (HC stands for high capacity), SDHC looks the same but they are actually different. And for "card not protected", that should not be a problem, since when a SD card is protected (if you click the little button on the side to the lock position) data cannot be written not deleted. So the solution is to use another SD card that your camera supports.
Oct 01, 2009 | Polaroid i1035 Digital Camera
Sd card problem
did you try to get another card or it doesnt take that certain card
Jun 14, 2009 | Polaroid i835 Digital Camera
I835 keeps saying card protected won't show pic taken
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 01, 2009 | Polaroid i835 Digital Camera
Cannot get new camera to install memory on sd card
No, it should work fine with the new one. If it's not working, make sure the card isn't locked. If its still not working, make sure the card isn't full and if that doesn't solve it, I would advise to get a new card.
Jan 28, 2009 | Polaroid i835 Digital Camera
Polaroid i835 Digital Camera Logo
174 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
