Question about Garden
My 2000 JD 345 has no spark at the spark plugs. It started and ran approx a minute or so and then when I gave it throttle it stalled and will not restart. Engine turns over great, no spark at plugs.
  • 162 Answers
Well if you cant fix it can I have it ? lol
check the magnito for rust build up
Posted on Jul 30, 2009
JD JS45 walk behind mover. Starts, runs fine for 5 minutes, then stalls, won't restart till i pull the spark plug and cool the motor, plug down. then same thing starts, runs for 5, stalls.
Probably either a fuel or a spark problem. You need to check for the presence of a good spark immediately the engine stops - by using a spark gap, a spare spark plug or a propriety spark indicator.
If the spark is found to be absent the fault is likely the ignition module but check all connections and the stop switch operation before replacing.
If the spark is present then the fault is probably fuel-related and is the sort of thing a tiny droplet of water in the carb could cause...
Jul 23, 2016 | Cars & Trucks
My JD 324 runs but will not pick up the load when the throttle is increase or the mower is engaged
Sounds like a fuel delivery problem. Filter? fuel tank outlet clogged? fuel shutoff valve not completely open? Other issues.
Apr 04, 2015 | John Deere 325 345 Tractor Service Pricing...
Engine only runs at idle
If it's a Chrysler/Dodge product, disconnect the battery for about 10 minutes and re connect it. Try starting, be sure the battery has a FULL charge when you do.
Oct 12, 2014 | Cars & Trucks
99 Volvo V70 seems to stall and vaporlock, after running. The car shows an ETS light, which I understand to be the Electronic Throttle Sensor. It has shown this light for over a year, but has not given...
change your fuel filter ..your vehicle will run but your fuel pressure is weak ..also after this clean your fuel injectors by pouring injection cleaner in your gas ,,it will correct itself..Also ,,if none of what I stated works ,,Spark plugs and new spark plug wires needed ,,Lastly your fuel pump
Oct 23, 2013 | 1999 Volvo V70
I have a 2000 suzuki Vitara I can drive a long distance but when I stop it wont start up like it out of gas, and one day I drove to get gas i fill up and started to take off and it stop like I ran out of...
(if engine is good, not overheated )
its only 1 of 2 things.
lost spark (do a spark test using , yes, a test good spark plug)
if spark is good on all cyl
then check fueling, if spark plugs not soaked in fuel (tips)
then try test fuel.
if soaked, the op guide says, hold throttle fully open (depressed 100%) this cuts INJECTIONS 100% and you start a flooding motor)
Apr 08, 2013 | 2000 Suzuki Vitara
Have a 2000 lesabre custom with 77000 miles has a problem with stalling on occasion and sometimes is hard to start, after stalling may have to let it sit a few minutes before it will start it's been into...
We recently worked on a buick century with the same problem. we replaced the spark plugs and made sure the spark plug wires where on their tight and it ran like new. i hope this helps. BE CAREFUL AND DRIVE SAFE.
Apr 23, 2011 | 2000 Buick LeSabre
Car ran great after fueling traveled approx 45 miles parked at a convenience store turned it off went inside upon returning to the vehicle it would not start. after a while it would try to start up but if...
It could be water in the gas or it could be one of your sensors. More than likely it sounds like bad fuel. But if you want to be sure is have someone check your fault codes. You can have it done where ever they repair cars.
Feb 22, 2011 | 2000 Buick LeSabre
JD 345 Having problem with ignition coil or ignition pulse. How do I check each? When it warms up the left side cuts out and may eventually stall. I pull the plug wire off it doesn't make any difference...
I have a Gx 345. Had a very similar diagnostic issue. Make sure you have a fresh set of plugs and have checked wires for abrasion. The best way to see, if you have a grounding out issue is to start tractor in the night and look for sparking on each side of engine.
Anyhow, after replacing ignition circuit board, the problem was corrected. Coils fail very rarly, if failed they simply don't work. Typically, an intermittant problem would point to circuitry or grounding issues.
Jul 07, 2010 | John Deere Garden
2000 sebring won't start
Crank Sensor is the likely issue. It does not throw a code. Key indicator is the call stalls all the time. R&R sensor.
Apr 01, 2009 | 2001 Chrysler Sebring
Garden Logo
322 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
