Question about GE GSH25JFR Side by Side Refrigerator
Top of GE Frig is not freezing at all. Bottom 1/3 seems to be freezing. Ice crystals on inside of back freezer panel.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 30, 2009
Ge profile 2004 open door and temp controls off shut door open they come back on light was staying on sometimes to bottom half of coils in freezor froze freezer working but temp in frig 50s on off fri
It is possible the refrigerator is low on Freon. You will need to remove the back panel inside the rear of freezer to examine the evaporator coils. If only a few rows have frost it will be time to replace the refrigerator. If the control panel in the freezer dispenser are coming on and off there may be a bad connection in the plug under the top left door hinge cover. Check that the plug is tight. Let me know what you see first behind the freezer wall, Thanks Sea Breeze
Dec 12, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE GSH25JFR Side by Side Refrigerator Logo
173 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
