Question about Whirlpool ET4WSKXS Top Freezer Refrigerator
Not defrosting,getting ice in vents. - Whirlpool ET4WSKXS Top Freezer Refrigerator
  • 3,267 Answers
Do a manual defrost, the auto switch short circuits sometimes, and therefore if manual defrosting works then you got to replace the auto-defrost circuitry. Also check if the thermostat is all right, otherwise that need a change too.....................................sodeep
Posted on Jul 30, 2009
2 Suggested Answers
  • 1796 Answers
SOURCE: defrost works fine but ice builds up in return
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Posted on Mar 20, 2010
What if the refrigerator side is not getting cold and the freezer side has a lot of lce on back but does not get that cold eather
Completely defrost your freezer and then plug it back in. A lot of fridges get there cold air from a vent connected to the freezer unit and that could now be blocked by ice. Your cooling coils also won't work correctly once they are covered in ice. So completely defrosting it and letting is sit open for a day or so to get the ice completely melted out of the vent and cooling coils should fix the both problems.
Mar 17, 2014 | Refrigerators
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Freezer is building up ice in the back which is blocking the vents. I have cleared the ice and tried to open the vents but 2 hours later its the same and the motor keeps running
If its again building up ice, that means the unit is not defrosting.Its starting the cooling procedure, then while defrosting, its not working.The defrost assembly consists of three main parts.The defrost thermostat, the defrost heater and defrost board.Any of the one is not functioning.When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works.Both thermostat and heater are controlled by defrost board.First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem.You can get required parts from from online sites like:--- www.repairclinic.com or from searspartsdirect online site. ----------- Before that you can try manual defrost reset procedure.The manual defrost reset procedure is as follows : ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. ------------------ This should help.Thanks.Helpmech.
Apr 05, 2011 | Kenmore Refrigerators
Since putting my Christmas turkey and ham in the frig, it has stopped cooling. I've thought the heavy load and maybe blockage of the ventilation was the cause. I've removed everything and investigated. ...
ertet
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
your refrig side will be warm or ice at the vent..
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 25, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Magic chef mcbr1010w, fridge not getting cold. freezer is not defrosting ice blocking hole down to fridge. love the fridge dont want to get rid of it. but im having to defrost freezer by hand every...
do a total, 24hour,defrost,with the doors open,(loads of towels)this should melt all the ice you cant see/get at.DO NOT use hairdryers/scrappers as they only do the surface ice.Wash out/spray all vents/drains with clorine bleach.(clorine is a gas and the smell will not permeate food if left to vent naturally) then switch onto fast freeze,check door seals are tight all round(hot cloth will help mould them).hope all works well for you/please leave feedback.ta!
Sep 22, 2010 | Refrigerators
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer isnt freezing yet ice is forming on the back wall
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Whirlpool 20.9 cu. ft. Top Freezer...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Fridge slowly gets warmer and stops working
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Jan 11, 2009 | GE Refrigerators
Whirlpool ET4WSKXS Top Freezer Refrigerator Logo
258 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
