CAN YOU BUY 1GB UP GRADE MEMORY FOR THIS COMPUTOR
CAN YOU BUY 1GB UP GRADE MEMORY FOR THIS COMPUTeR AND IS IT EASY TO REPLACE
  • Laurence Reeves
    Laurence Reeves May 11, 2010
    As in RAM or Memory like the hard drive?
  • 746 Answers
Yes! it is possible and it is very easy if your motherboard supported it. You can replace.
Thank You
Posted on Jul 30, 2009
I pluged my phone into my computor to download my photos, now there all gone
YOUR PHOTOS WERE IN THE MEMORY CARD?
IF YES YOU CAN TRY USING A RECOVERY PROGRAM IN A COMPUTER (EASY RECOVERY PROFESSIONA, RECUVA, OR Stellar Phoenix Windows Data Recovery - Professiona)
Dec 17, 2013 | HTC Desire Cell Phone
My e-machines will not let me upgread my ddr2 1eb memory
That Machine would take DDR2 PC2-5300 upgrade chips. The max that system could take would be two 1GB sticks for a total of 2GB or 2048MB of memory. Memory is fairly easy to damage with static discharge and is also very easy to not put in all the way. When putting it in, unplug the power from the computer, push and hold the power button for 20-30 seconds to help discharge power from the computer, Line up the pins on the memory and push them into place till the little arms at the sides of the slot pop up and click into place. I'd install one chip at a time, powering the machine up after the first chip to make sure it works, then starting over again. The only time I'd install both chips at the same time would be when installing a memory kit (two or more chips in one package), in which case, install both chips before powering it on.
Jan 13, 2013 | E-Machines T5082 PC Desktop
I have a 150gb hard drive with 2gb memory. How can I upgrade my hard drive and memory
As with most laptops, there are two memory slot. This laptop has 1GB in each. You need to remove one or both and replace with 2GB boards. The 2gb memory boards are around $50 or so. Changing memory is easy to do.
Replacing a disk is easy also, but you need to get your programs from the old disk to the new. That usually takes a local shop to do that. You may just want to buy a new computer instead of upgrading.
Sep 13, 2010 | Toshiba Satellite P205D-S7802 Notebook
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
Sony Vaio not recognized installed memory
Swap the modules between the slots.
If the message shanges to slot 0 not recogonized, then you have a bad memory module,
Easy fix, just get another module.
If the message does not change, then you have a problem on the mother board.
Not an easy fix, it would be cheaper to buy a 1GB module and use the good slot.
Good Luck!
Jan 24, 2010 | Sony VAIO GRV670 Notebook
Memory slot?
Your computer probably does not have one of those slots if you can't see it on the front of the computer. There are adapters you can buy that will hold the little camera memory cards. They plug into a USB slot. We have one that we use. I also use one that has 4 slots on it for several types of memory.
Jan 21, 2009 | Dell Latitude D600 Notebook
Upgrading my laptops memory
If it has two simms slot available you can, but I suggest better use the 1GB
Dec 13, 2008 | HP Pavilion dv1000 Notebook
My medion radeon x740xl graphics card cant cope with new games.
Your computer has a PCI Express x16 connector. You can replace the card for less than $100; for example, a 9600GT card from NewEgg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127382
Note that card is designed for a PCI Express _2.0_ x16 connector. The card will be more capable than your computer, but will slow down to work with your computer. It's a solid card, reasonable price.
You may want to evaluate how much memory you have and consider upgrading it if you have less than, say, 1gb. Memory's cheap.
Dec 05, 2008 | Medion M3 Director 5100 PC Desktop
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Memory
Buy the 2 - 512MB memory, and put them in. You will not lose anything.Everything is on your hard drive, not in resident memory.
Jan 30, 2008 | Acer Aspire 3502WLCi Notebook
Computers & Internet Logo
David Payne
David Payne
