Question about Ryobi Multi-Volt Battery Charger
Green and yellow lights are on battery will not charge
  • 20 Answers
Your battery will not charge if you have used it till the point of gettig flat that the battery is warm, the battery as to cool down first. also your battery has a life on it as when you charge over and over the charge will lesten each time, so you may need to change your battery failing that your charger may be no good.
Posted on Jul 31, 2009
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
Hi. I am charging up my battery for my Harley and am using an oxford oximiser 600, but have lost the instructions. I would like to know what the two lights are to either side of the four lights. They...
You have the four coloured lights to show battery state Red - irrecoverable; Orange - 3 to 6 Volts in the battery, Oximiser will attempt recovery; Yellow - 6 to 12 Volts in the battery, Oximiser will charge and and optimise and Green - Full charge, about 14 V, the Oximiser will maintain the charge.
On the left of this you have a Green light to show that the Oximiser is connected to the mains and on the right you have a Red light to show that you have connected the charging leads thewrong way around, i.e. the positive charging lead is on the negative terminal and the negative charging lead is on the positive terminal. This light should be off.
Sep 29, 2010 | Harley Davidson FLSTC Heritage Softail...
Ryobi 18V cordless drill the yellow and green light is on when charging what does this mean
I have found when I put a battery on to charge and the green and yellow light turn on the battery is low voltage and the charger will not charge the battery ( bad battery)
Nov 12, 2009 | Cars & Trucks
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Homelite trimer 18.0v charger, battery, yellow
homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
Sep 12, 2009 | Homelite Garden
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi Multi-Volt Battery Charger Logo
630 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
