Question about Intex 15' X 42" Easy Set Pool Complete Pool Set
I bought a 15' x 4' intex pool from my brother in law and the skimmer and hose set up is on but i dont know if its right what to do?
  • 297 Answers
Check out the pdf files and videos
All intex pools and filters are basically the same you should learn what you need to from them
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Posted on Jul 30, 2009
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
Intex pool surface skimmer keeps floating up.
i solved this with a few fishing weights in bottom catch cup takes a little experiment (more/less) to get it floating just right but once you do it works all summer
May 30, 2012 | Intex Surface Skimmer Pool Vertical...
How do you bleed the lines to the pump?
I usually run a water hose down the skimmer basket drain for a while until water is returning to the pool through the pump. I hope this helps.
Aug 13, 2011 | Intex 15' X 42" Easy Set Pool Complete...
Skimmer and Vacuum set-up question
Here is a link to Intex website for the manuals and videos. Intex Pool
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Vacuum
ok, if u connect the vacuum plate to the skimmer then u need to submerge the hose all the way or the way i do is use the water from the return ( where the clean water returns to your pool and put the hose up against it to where the hose is filled with water and it will sink a little bit, This gets all the air out so it will be easier for the vacuum to get suction. Once u get the water in the hose by either submerging it or using the return water then connect the vacuum plate and then put it on the skimmer...it should start suction right away but if it doesnt that means u didnt fill the hose up all the way or u may need to just giggle the hose a lil to get it to start the suction....I hope this helps, let me know
Thanks and God bless
Jun 23, 2010 | Intex Easy Set Pool 15x36
Where does the skimmer sit on an intex metal frame pool
i have mine sitting about a foot to the right of the intake on the pool, that way it keeps a clear line from the skimmer to the intake to the pump/filter to the outlet
May 30, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
I have an Intex 15' x 42" Easy Set pool. I bought chlorine tablets for it, and thought I could put them into the skimmer basket. Now I'm not so sure, and I can't get the DVD to play, and I've lost the...
Buy an inexpensive floater for in the water and put them in there. Putting them in the skimmer will just shorten the life of a pump that will already struggle to give you 3 years of service.
Jul 31, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex 15' X 42" Easy Set Pool Complete Pool Set Logo
233 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
