It's under the right side of the instrument panel .
Remove the right side instrument panel I/Pinsulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages, and Console.
Reposition the BCM aside. Refer to Body Control Module Replacement in Body Control System.
Disconnect the blower motor electrical connector.
SOURCE: installing blower motor on a 2000 alero
its on the bottom passenger side of the dash on the theres a plastic panel held by clips
SOURCE: blower fan not working correctly
It is the blower motor resistor and is located under the glovebox behind the blower motor.
SOURCE: 2003 Oldsmobile Alero Thermostat/Fan Trouble
they should turn on at about 213 orbetween 200 and 215 dont let it go over 230 if so please turn off
SOURCE: I need to know the location of the blower motor
under the dash on the passenger or under the hood on the passenger side
SOURCE: fan motor for cooling rear of 2003 pilot not operating
Center console need not be removed. Right side kick panel needs to be popped out, exposing the fan motor assebly. There are 3 screws securing the assembly to the duct. Remove the screws using a flathead screwdriver, unplug the unit and pull it out. The challenge will be finding a replacement motor, as they are not sold anywhere other than the dealerships (at an outrageous price)
