Question about Welding Tools
We have a dielectric welder model HFT-10 made by High Frequency Technology Inc.They are no longer in the dielectric business so they can't help me. The problem is when you cycle the machine it operates normally until it is time for the RF to fire.When it does it blows the main breaker at the power source.I have changed the breaker to insure that not being bad but to no avail. The other problem is I do not have any kind of book or even electrical schematic so I don't know were to start.I don't know what is suppose to have continuity and what isn't.Can some one help?
    President:
  • 1,714 Answers
This is a pretty complicated machine and you will need professional help to diagnose the problem There is an electronic tube (similar to the old vacuum tube technology of the '50's) that generates the high frequency necessary to weld with. I found a company that makes high freq. welders and you may be able to go through them.
You may be able to find a Radio Technician that would understand the principals involved in the high frequency generator and how to troubleshoot it. It may only be a problem on the low voltage (240VAC) side of the welder that is causing your problem. A good electrical technician/electrician could troubleshoot most of it. here is a link...
http://www.made-in-china.com/showroom/steveliury/product-detailNqunwEHvfgcy/China-High-Frequency-Welding-Machine-NAR3000-.html
Posted on Jul 31, 2009
How to set up welder or aluminum tig welding
If you want to weld aluminium with a welder, your machine must be an AC/DC welder, then you will use only AC to do the weld, but as well you must have a contineous high frequency and according to what thickness you want to weld a water cooling argon torch wont be a luxury
Aug 25, 2014 | Welding Tools
Low voltage at recepticials
If the front DOES NOT say "chopper technology", then the fine control knob MUST be turned all the way up for full aux power. Low engine RPM can also cause this issue. If your meter can read frequency, it should read a little above 60 Hz at full speed with no load.
Mar 12, 2014 | Lincoln Ranger 225 Engine Driven...
No high freqency on tig welder/longevity weld 160pi
Replace your high frequency capacitor. Patrick
Nov 22, 2013 | Welding Tools
Have a CT-200 Hobart Welder Getting high frequency but no current?
Sounds like the problem could be with your tig torch. Inside the tig torch you have a copper cable which carries your main welding current. If there is a break in the copper the high frequency is of such a high tension voltage that it can jump across the break in cable making it appear that your tig torch is fine. If you have a multimeter check continuity from one end of the torch to the other or try another tig torch.
Nov 06, 2011 | Hobart Handler 140 Mig Welder
Welder alluminun
to weld aluminum with a tig welder the machine must have a high frequency ability.
Sep 26, 2011 | Welding Tools
If I am using a 150A High frequency TIG welding machine, would you recommend a torch with gas control valve or not
You should control the normal gas flow at the bottle with a flow meter. Your welder may have additional settings such as 'post gas' and 'pre gas' to start the flow before you press the button or keep it going for a short time after you release it.
Sep 07, 2011 | V, Inc. Weldcraft Wp17v Weld Like A Pro...
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
Lincoln Idealarc tig 250 has no high frequency
Check high voltage transformer and capacitor, also check point gap circuit to ground.
Jun 20, 2009 | Welding Tools
I have a Clarke MIG welder, the recifier has shorted out. I need a new rectifier PMS 8/4/1 F (Clarke P/N WE20504-22400038) Clarke is no longer in business so I am unable to get the part from the...
I have a brand new rectifier for a clarke 130 welder new still sealed in plastic bag--is this what you need---look in craigslist,long island for pics
Mar 06, 2009 | Clarke Power Products Welding Tools
Welding Tools Logo
139 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
