Question about Miscellaneous
Why does my Cirrus OCT 4000 freeze for a few seconds while acquiring an image?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
I should start by telling you that I am not familiar with this device!
You probably have a maintenance contract with this device, try speaking to technical support.
Speed in general will be a product of image size, memory size, processor speed and if applicable data transmission speed. In addition resolution options, or requiring extra information from the image will also impact the speed.
Posted on Jan 13, 2018
Can you change motor and trans in a 1998 chrysler cirrus from bottom of car or does it have to come out top
Dodge Automatic Transmission Removal - YouTube
? 11:05
https://www.youtube.com/watch?v=zuGO78R8BfU
Oct 27, 2010 - Uploaded by richpin06a
Dodge neon automatic transmission replacement. ... a chain block which means you have a lot more room under the car for working space to ... I didn't read the title and I thought I was watching how to change tranny oil. ... Then you can slid theengine a little to the pass side and you can pull the engine out.
Chrysler Cirrus Repair: Problems, Cost and Maintenance
repairpal.com > Cars > Chrysler
A guide to problems, costs, maintenance and repair for your Chrysler Cirrus ... CheckEngine Light Due to Pinched Leak Detection Pump Vacuum Lines ... 1998 Chrysler Cirrus ... This is typically found where the wires pass under the distributor. ... The carturns over but won't start can't smell gas even when you keep ...
Nov 30, 2015 | Chrysler Cars & Trucks
What does a shaft speed sencer do for a 2000 cirrus
According to Stratusphere.net, "Symptom: The car won't shift out of 1st gear. The 'Check Engine' light is on.
The speedometer doesn't work for this one. You're only able to go about 30 MPH without going above 4000 RPM.
Likely Cause #1: The Output Shaft Speed Sensor went bad.
Likely Solution #1: Replace the sensor (Part #4800879)."
The good news is that they are relatively cheap if you can install them yourself.
Apr 03, 2015 | 2000 Chrysler Cirrus
How do I clean the Zeiss Cirrus HD OCT Model 400, 4000 between Patients?
Just with alcohol and cotton, nothing else, you should only clean the head rest and the chinrest
Oct 17, 2014 | Zeiss Cirrus 4000 Spectral Domain Oct Hd...
Why does my Zeiss OCT "freeze and shut down" during capture ? Sometimes it works fine and other times it freezes and shuts down.
Salam
Related to my work i found that when capturing very thin retinal layers or very un familiar deformaties that not have normative data bais referances
Sep 01, 2014 | Zeiss Cirrus 4000 Spectral Domain Oct Hd...
Was does "unable to track" mean and should we repeat those scans
Salam
mostly is related to media block either cornea,lens vitreous rarly happen with me due to retinal fibrosis.
but these after all optimize focus enhance and correct of refraction + or-
Jan 16, 2014 | Zeiss Cirrus 4000 Spectral Domain Oct Hd...
Error message unable to read analytical data
Salam
this happen after patienwith poor fixation and trying many time capturing scan .
also with very very abnormal tissue thickness.
Oct 16, 2013 | Zeiss Cirrus 4000 Spectral Domain Oct Hd...
My 2000 cirrus rattled for a few days then yesterday rattled loudly and died. I restarted it but then it died again immediately and would not start at all. Took it into the chrysler garage and they tell...
How can someone make that judgement for
you,it is your money
I would fix it myself
I certainly wouldn't be at any dealer
after the warrantee ran out
Jun 17, 2011 | 2000 Chrysler Cirrus
2000 Chryler Cirrus - engine races all the time
Either the throttle body is being held open by something or the idle control valve is stuck open. Check where the throttle cable hooks to the throttle body, make sure the cable is not caught on something.
Jan 10, 2010 | 2000 Chrysler Cirrus
Garmin 350 not acquiring - solved
This is a common problem. Even though the wire gave you reception, you still have a bad part in your GPS. Please see this link for more detail:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Oct 24, 2009 | Garmin nuvi 350 GPS Receiver
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
