Question about Whirlpool Refrigerators
The fridge is running, but isn't cold at all. tried cleaning the coils, but it didn't work.
    President:
  • 1,188 Answers
Needs refrigerant. Ask a technician to check refrigerant pressure.
Posted on Jul 30, 2009
My Westinghouse Rp241T fridge is not getting cold. I can hear the motor running but it isn't cold. The fridge isn't very old and I suspect the thermostat?? Where is it located or am I off the...
Hi, Sounds like there was/is a leak in the refrigerant system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
The freezer works fine; the refrigerator isn't cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2011 | Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
The refrigerator is not cooling
heatman101
Jul 26, 2011 | Amana Refrigerators
Hi, Have a Westinghouse Fridge/Freezer BJ414BQ-RWZ, approx 14 years old. Has recently not keeping cool enough. Looking for tips on what I can do to correct. Tried turning a white knob on rear/base of...
heatman101
Jun 04, 2011 | Westinghouse Refrigerators
My fridge is cold but the freezer isn't frozen
heatman101
May 27, 2011 | Kenmore 50522 / 50524 Side by Side...
Freezer Working Intermittently; Fridge not as cold as should be
the model number you sent didn't come up,i sounds like you could have an inefficient compressor or a freon leak.when you checked the compressor was the condenser fan motor running?this is what keeps the compressor cool also clean the condenser coil too.another thing is that if you have a timer on your machine it could be sticking,if you send the model number i can tell you where it is,also if you remove the back inside wall of the freezer,look at the evaporator coil,the frost on the coil should be the same over the whole coil,if it isn't you have a sealed system problem and will need to replace the machine.if things are cold in freezer but not cold enough this is what it sounds like,do this,open the freezer door,you should hear the fan blowing,if not the evap fan motor is bad or it could be in defrost,if you don't hear the fan blowing wait around a half hour and check it again, it could be in defrost mode so the fan won't turn on until it comes out of defrost,also like i said make sure the condenser fan motor is blowing and the condenser coil is clean,if everything checks good and the freezer is cold but not cold enough and the best thing to check is the ice cream get a new machine,you have a sealed system problem.let me know what you find and good luck
Jan 05, 2009 | Kenmore 65812
Refrigerators Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
