Question about Acer Aspire One PC Notebook
The battery does not charge
It works only with the adapter on it
    Master:
  • 404 Answers
Needs new battery, lifetime is 1 to 2 years.
Posted on Jul 30, 2009
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Satellite laptop battry don't charge
Take out the battery and only hook up the AC Adapter. If the laptop turns on then that means the adapter is working. Now hook up the battery and see if it charges. If it doesn't then that means the battery is bad.
Try another battery, if the new battery doesn't charge then that means that the AC Adapter is bad because its not putting out enough voltage to charge the battery.
May 31, 2010 | Compaq Presario 700 470024-192 Notebook
I have a Epc note book and it will take a charge just received i
You say the laptop battery not charge or the Epc can not work with the adapter?
First you try to charge a fine battery with your adapter to confirm the adapter is good or not.
Then use the good adapter to charge your battery to confirm the battery is dead or not.
You should change your adapter or battery.
Jan 18, 2010 | ASUS Eee PC 900HD Netbook
Battery not charging
this is usually an adapter, battery or mobo failure. Since the same adapter fails, that leaves the battery and motherboard. power on the system without the battery to confirm if the adapter still works. if AC works, try another battery and see if this works. If yes, the battery needs to be replaced. contact dell and check if a replacement is possible if your battery is still within warranty. I beleive dell only warrants battery of laptop for a year from the date your system was originally purchased.
Apr 07, 2009 | Dell Inspiron 1525 Notebook
Notebook is not charging, even when the ac adapter is working.
definately sounds like your battery might have went bad on you. Try to find one that you know works and see what happens in your machine.
Dec 24, 2008 | Acer Aspire 7520-5185 Laptop
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Acer Aspire One  PC Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
