Question about Proscan PS52662 52" Rear Projection Television
I have a PS52652 and i cant get the display to move to the center of the screen. it is off the left of the screen
    President:
  • 1,188 Answers
Go inside the menu and manually adjust H/V position in the picture settings.
Posted on Jul 30, 2009
I can't get my icons and taskbar to center on my monitor. The start button is off screen to the left. How do I center everything so I can access them?
Press the OSD (On Screen Display) button on the monitor.
Use the UP/DOWN and LEFT/RIGHT buttons to navigate through the menu, to get to the "horizontal position" menu.
Press the OSD button to "select" that setting.
Press the LEFT/RIGHT buttons to "move" the image LEFT/RIGHT.
Press the OSD button to "apply" the new location.
Wait a few seconds, and the OSD menu should close itself.
Oct 24, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
My computer screen is turnd sideways some how and i was cant figure out how to fix it
Ctrl + Alt + arrow keys.
Up gives you normal, Down gives upside down, left and right give 90deg rotation.
Try Ctrl+Alt+ Up Arrow, should come back to normal.
Nov 02, 2009 | Dell Latitude D610 Notebook
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Can these TVs still be repaired
Can be fixed see bad connections on flyback and bad fuse comeing off theis connections should fix
Dec 22, 2007 | Proscan PS52650 52" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
