Question about Dyson Vacuums
I have a dyson v7 direct drive motor head that won’t turn, I took it off to clean it, put it back following instructions and now it won’t turn, there are no blockages
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
Dysonteam
  • 167 Answers
SOURCE: hi, i took apart filters to clean in my dyson dc25
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at www.dyson.com and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 16, 2010
Testimonial: "I went to the dyson website...and figured it out thru pictures. Thank you!"
  • 10 Answers
SOURCE: i opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Posted on Jul 29, 2010
VacuumRepair
  • 438 Answers
SOURCE: There is no suction from
Hi Doug,
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free, rather then just the premium ones that users pay to have answered. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
Posted on Aug 09, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My Dyson DC25 won't turn on when in the upright position.
    I'm sorry to hear you're having difficulties with your DC25. This issue sounds unusual, and we'd appreciate the opportunity to provide further assistance. Please get in touch with us directly by calling free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will help if you have the machine to hand when you call.
    We'll look forward to helping you resolve this.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Feb 06, 2012
    Have a Dyson v6 for several months. Roller brush stops turning a soon as I start to push forward after staring trigger. Examined & cleaned roller & surrounding head & find no objects interfering.
    The Dyson V6 has an electric motor in the power head. The battery is in the handle unit. So power has to get from the battery head unit down to the motor at the floor roller brush. The way they do this is to send the power around the plastic debris cup that you empty, and then into the connector for the tube and out the bottom of the tube to the roller brush motor. Your problem is probably that there is a lost contact along the way. Try plugging the roller brush directly into the head unit leaving the tube out and see if it is intermittent or if it runs fine. In that case the problem is one of the contacts associated with the down tube. If the roller brush is intermittent even when plugged directly into the head unit, then the problem may be the connection associated with the debris cup. remove the cup and make sure the contacts are clean. Hope this helps. G
    Oct 26, 2016 | Dyson Vacuums
    Where is the reset button on a DC24 ball?
    Hi there, it's Jack at Dyson.
    In most cases, DC24's reset button should be located in a red recess on the side of the cleaner head, as shown in the video guide below. It may help to use something like the eraser-end of a pencil to press the button - you should feel a click as it engages.
    Some newer DC24 variants don't include a physical reset button, and instead the reset mechanism will activate when you turn off the vacuum, then turn it back on and recline it into the normal vacuuming position.
    If you can't see a reset button on either side of the cleaner head, this may be the case with your machine. If you're unable to reset the cleaner head, please contact our experts directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Feb 14, 2015 | Dyson DC24 All Floors Upright Cleaner...
    The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
    hi russ, it's jack at dyson.
    i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
    if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
    Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
    Why doesn't the Dyson work at base with brushes
    Hi Barbara,
    I'm sorry to hear you're having difficulties with your DC14. If your machine has suction through the wand, but not through the cleaner head, it's likely that there's a blockage somewhere in the cleaner head. The filter may also need a wash.
    The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=622&product=DC14-ANIMAL_US
    This should resolve the issue - however, if you'd like further assistance, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US) so we can help.
    Kind regards,
    Jack
    Nov 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    I put a new battery in my 5 year old Dyson DC16, after a couple minutes in the charger the vacuum turned itself on and ran until the motor (circuit board) burned up. I bought a new Dyson motor assembly...
    Sorry to hear you're having difficulties with your DC16. Although your cleaner will no longer be under its original 2 year warranty, the new motor assembly would be covered by a 12 month warranty if you purchased it directly from Dyson. As long as the cleaner has been used in accordance with the terms and conditions described in the manual, we should be able to replace this for you.
    Alternatively, we could arrange to have the cleaner returned to us for further inspection.
    In either case, please get in touch with us directly so we can discuss the issue further. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We look forward to hearing from you.
    Kind regards,
    Jack
    Jul 31, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    Motor won't engage when release handle to vacuum.
    Please look at this URL for operating instructions, floor adjustment, etc.
    http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
    If you feel you are following the directions and still not getting the motor drive, check for broken belts and/or frozen beater brush. Will be happy to go further if this solution does not solve your problem. Paul
    Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Hi, i took apart filters to clean in my dyson dc25 and put it back together as said...and now its making a highpitch whinning sound
    Kind regards
    Darran
    Apr 15, 2010 | Dyson DC25 All Floors Bagless Upright...
    Dyson dc 17 vacuum. brush not moving
    The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
    Apr 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Putting the turbo head brushes back on to a dyson dc14 vaccum cle
    Congratulations on owning a great vacuum cleaner, it's just like mine! Here's what I do: Grab the drive belt and pull while you wiggle the brush bar into it. You have to get a little bit physical with it. The ends of the brush bar will nestle into their keeper pockets nicely when you've got it right. Good luck!
    Sep 20, 2009 | Vacuums
    On button won't stay on
    easy fix, unplug the machine sit in front of it. put your thumb on the on/off button and push down and slip your thumb off of it as fast as you can so it pops real loud. Do this ten times and then plug back in and see if it works. ( this came from talking with Dyson people) Hope it works for you. They said this will reset the machine. also acts as a warning that your filters most likely need cleaned.
    May 21, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    32 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
