Question about HP DeskJet 3325 InkJet Printer
Have tried to connect my laptop with vista home premium using your deskjet 3600 online as suggested for my 3325 printer but when i go to print a test page the printer feeds in the paper and the print heads behave properly as if they were printing. I have checked that with the cover up and switch held down.I have cleaned the print heads as per instructions and have checked for ink quantity but it still wont print. It is almost as if the ribbon cable to the carraige has a fault. any suggestions please. Mike Hill-Smith
    President:
  • 1,188 Answers
Install correct driver. Cartridges may be damaged.
Posted on Jul 30, 2009
  • Adnan Bhatti
    Adnan Bhatti Jul 30, 2009
    Install correct driver. Clean copper contacts on the back of the
    cartridges with a dry tissue paper. Does ink come out when you put the
    cartridge head on a tissue paper?
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
Hp 3325 printer printing test page and not printing other pages
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP DeskJet 3325 InkJet Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Can't print with hp deskjet 3325
delete all of the hp software, reboot windows, remove anything in "add remove programs" that looks like it belongs to HP, reboot again, then plug in printer wait for it to detect it, then reinstall software.
t
Nov 18, 2008 | Computers & Internet
My hp deskjet 3650 will not print webpages
hi jedjames707-
this is a common concern and there are a few links from HP's support site that might help.
depending on your operating system, you might find HP Smart Web Printing is fun to use:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-56929-4&cc=us&lc=en&dlc=en&product=3551212
Compatibility:
s.gif Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows XP Professional, Microsoft Windows XP Home Edition
general info for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=304535&lc=en&cc=us&dlc=en&lang=en&cc=us
general support links for your model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535&lang=en
and some general tips for printing from the internet:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00064977&dlc=en&product=303753
hope these help a little!
-JW50
Oct 13, 2008 | HP DeskJet 3650 InkJet Printer
IOGEAR GBP301 and HP Deskjet D1341
Please make sure that the printer is already VISTA compatible meaning if it is known to have VISTA printer drivers.
Jan 17, 2008 | IOGear GBP301 Print Server
HP DeskJet 3325 InkJet Printer Logo
255 people viewed this question
Seeker5211
Seeker5211
