Question about Dynex Enhanced-G Wireless Broadband Router
No wireless signal is coming from router - Dynex Enhanced-G Wireless Broadband Router
  • Fahad I MEMON
    Fahad I MEMON May 11, 2010
    are all cables connected to router
    Sergeant:
  • 366 Answers
Sometime radio section is gone and router is perfectly working on wired side.
Update to latest FW and check manufacturer KB.
If issue persists call for subs.
Posted on Aug 02, 2009
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
What is difference in wireless routers?
The have different signals, usually either B, G, or N. Those signals provide access to devices of similar signals.
If you have an old wireless router with B or G, it may not even recognize a N product. Usually N routers will pick up B & G product signals.
Security is also a factor. Improvements in security have been made and the newer N model should provide the best protection of your data. Also, speed and distance are factors that change from one manufacturer to another & model to model.
Generall, these days you want a N router with wireless and wired capabilities and they come with many options to review.
Good Luck
Mar 25, 2012 | Linksys Wireless-G Broadband Router
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 12, 2012 | NetGear DGN1000 Wireless Router
What is the ssid
Ok SSID stands for Service Set Identifier. When you have a wireless device, the signal that it is transmitting needs to be given a name so that its signal can be seperated from all the other signals in a particular area. For example if you have a BT Home Hub wireless router and a Netgear wireless router, when you carry out a wireless signal search they will come up as 2 different names. If you are trying to set up your Wii for wireless access you can choose for your Wii to search for SSID's automatically. If you don't know your wireless routers' SSID you can look on the back of it and it should be on a label or on a card supplied with the router. I hope this helps you out and thank you for using FixYa
Aug 18, 2010 | Nintendo Wii Console
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
My router's signal keeps coming off after every
Try to call router manufacturer, you might need to upgrade the firmware of the router or just simply reconfigure your router settings.
http://technicalsupport.blog.friendster.com
Sep 18, 2009 | Linksys Wireless-G WRT54G Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
Broadband router range
If you have wireless N router. You should install wireless N adapter on your children's computers as well. That way, they are compatible with each other coz I guess your children's PC has wireless G adapters. You wont be able to utilize the N signal of the router if your using wireless adapters..
May 15, 2008 | Computers & Internet
AirDash USB stick problems finding the wireless signal from the router
you may need to go into the wireless router and turn the wireless option on,
if you have set up a security key, or one is set up automatically you need to put that key into the software of the Airdash USB stick setup,
good luck
Terry
Mar 31, 2008 | Computers & Internet
Dynex Enhanced-G Wireless Broadband Router Logo
221 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
