Question about Element Electronics FLX1510 15.4 in. LCD TV
I need the mosfet 40P0320 to repair the tv where canbuy
  • 50 Answers
Prs electronics components u.k.
Posted on Jul 30, 2009
LCD TV back light comes on for 1-2 seconds and goes off. What could be the reason?
not much of an answer maybe but as electronic components are nearly modular these days instead of making a repair that might not last very long it might be better just to replace the backlight. My repairs have, over the years not lasted more than a few years at best.
Good Luck with it
May 29, 2015 | Televison & Video
Viewsonic n3250w LCD-TV
That chirp indicates a feedback on the secondary transformer in the switch mode power supply and needs to be either repaired or replaced. A good shop can have this one back up in an hour or so - assuming they have the parts on-hand... If they have to replace the SMPS you'll naturally have to wait a few days. Most shops don't have such specific parts on-hand and will have to order it.. Replaced an entire SMPS for an Akai recently with the same symptom, chirping. Turned-out to be the regulators and two MOSFET's. A MOSFET is a metal oxide semiconductor field effect transistor.. In laymen's terms a switching gate. But below the two MOSFET's, when they went thermal they burned the board and several small traces which could not be bridged. The SMPS was $70.00 plus shipping, and you're probably going to be somewhere in that ballpark on this too if the whole SMPS has to be replaced. Good Luck Bill
Jun 05, 2007 | ViewSonic NextVision N3200w 32 in....
TV LOEWE 8784. Died SPP11N60S5 in the power supply. After replacement of the MOSFET the TV worked for a day then next morning it died again on a start. This way were killed 3 MOSFETs. What could be the...
Possible that when the MOSFET'S were changed the Switch mode oscillations were not proper and so the drivers were driven too much to fail.
It will be best to replace the whole power supply if the mosfets are heating up more than required.
Also replace all the electrolytics and check the SM transformer after the mosfets are replaced and before switch on. Check also the load on the output , if there is any short or leakage on the drive output .
Aug 04, 2011 | Televison & Video
I accidently put my power wire into ground terminal and ground wire on power side for a second and it sparked. The amp power light still comes on but the sub barely movees. Is there any way i can fix this...
No,your amplifier probably has damaged power supply transistors as a result of improper power connections,contact eric @ Capital Audio & Electronics repair 850-339-1130 in Tallahassee,Fl-we repair all namebrands & all models
Mar 17, 2010 | Alpine MRD-M1005 Car Audio Amplifier
Do i need a remote to aquire the av input on the tv
I believe on the Toshiba 14AF44 that you can change inputs by using the channel button on the front of the TV, as well. Either channel down to the lowest channel and then channel down again to start going through the available inputs, or channel up to the highest channel and then channel up again to start going through the available inputs.
Hope this helps!
Feb 18, 2010 | Toshiba 14AF44 14" TV
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
I think it's usually about 820 - 1K Ohms... It;s the emitter resistor.In saying that we generally don't repair these SMPSU's anymore as they are so inexpensive these days like NZ$45.00 for a 350 Watter. Also 80% of the time the repaired supplies fail again shortly after due to the stress put on the other components, by the initial problem.Good luck.
Jan 27, 2010 | Computers & Internet
Can i buy parts to my phillps tv as there is no picture showing only sound
My friend , as you present your problem , i see that you are not a technician. Don't attempt to repair by your self your TV, because you can act unsafe and put your life in danger and your equipment who is valuable.
Yes , you canbuy the parts, please if you can email me at semirengeee@yahoo.com , i will help you out.
Sep 15, 2009 | Televison & Video
MY TV STOP AFTER BEGINING
i need m# if you don,t have eny power noled in front of tv a green lite ck out fuse if that good. ck hozoutput it by the flyback most of time if the hozout is bad you should replace flyback the part#
is on the side a tag.the hozoutput the # you can se it. if you have a onm metter you can ck the hozoutput in dioe mod.
i till you this you can call me if yon need to 518-798-7560 ask for robert i see what i can help you?
Apr 22, 2008 | RCA P52937 52" Rear Projection Television
Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Jan 21, 2008 | Olevia LT23HVX 23 in. LCD Television
Element Electronics FLX1510 15.4 in. LCD TV Logo
141 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
