Question about Alpine MRV-F540 Car Audio Amplifier
Amp keeps cutting on and off
Hi i have a 1000 kenwood amp and it keeps cutting on and off when i put a 30 amp fuse in, it blows the fuse but when i put in a 40 amp fuse it plays and once the bass kicks in after about 30 to 40 seconds it cuts off, and stays off for about a minute and then cuts back on and then it will repeat the same thing again. do any of yall out there have any suggestions for me? Thanks, Cedric Ward
  • 3 Answers
Do you own a capaciter if not get one. If that dont help check all your wiring make sure it is the proper thickness and lengths.
Posted on Jul 30, 2009
30 amp fuse keeps blowing
check for hot wire with cut in insulation either by frame or going through frame probably red or black wire also check lights and plug
Sep 20, 2015 | Jayco 2014 White Hawk Ultra Lite 24RBS
Blows the 30 amp fuses
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Ford f350 diesel truck 30 amp fuse keeps blowing.
Dec 27, 2009 | 2000 Ford F350 Super Duty Super Cab
My 1800w kenwood amp keeps blowing the fuses
there are 3 reasons your amp is blowing fuses. The first is that it is no good. If amp plays at all then that is not the case.
Then it is more likely 1 of or both of these 2 reasons.
  1. The fuse is too small for the load you are putting on it and needs a bigger one.
  2. You have the amp wired to an ohm load that is too low.
Try upping the fuse to the next size up.
If the amp just blows the fuse and will not work at all. It may be shot.
Dec 02, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Fuel ECU fuse keeps blowing (30 amp)
Your fuel pump is internally binding and causing the fuse to blow. Change the pump (and filter while you're back there.)
Jun 14, 2009 | 1993 Jeep Wrangler
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Apr 25, 2008 | Car Audio & Video
http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Thanks
Feb 15, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Alpine MRV-F540 Car Audio Amplifier Logo
202 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
