Question about Thetford Porta Potti
Toilet won't flush. New pump fitted fuses ok.
Thetford Model Cass C2 L TC WHI - Toilet won't flush. There is power to the switch and flasher. Any ideas?
Posted on Aug 30, 2009
Put meter across fuse and it was faulty but it looked ok. New fuse and it's working.
Posted on Jul 31, 2009
2007 Fleetwood Williamsburg fold down cassette toilet won't work
If you're using water out of the fresh water tank then the toilet gets water from the same water pump the sinks and shower does. If they work OK then there's an internal toilet part that has broken.
Sep 16, 2017 | Cars & Trucks
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Motorhome toilet won,t flush
Make sure the water supply to the toilet and the pump are working properly, make sure waste tank is not full, if it still won't flush check the flushing mechanism on the toilet.
Mar 01, 2014 | Sport & Outdoor - Others
Sanislim keeps on running
does anybody know where you can purchase spares for the sanislim just im looking for a replacement motor?
Feb 26, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
Toilet won't flush...seems like no power
hi i have a thetford casset toilet but my flusher is not working i have cheked fuses but i am stumped now please help
Oct 18, 2011 | Thetford Porta Potti
Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I've just fitted a Nabis breeze and am having flushing problems.
Well many toilets flush very high before flushing, they appear to almost overflow, but if that doesn't seem like your problem, I would recommend adjusting the float on the Fluid-master fill valve so that there is less water in the tank when it flushes.
Apr 16, 2010 | Hansgrohe E & S Accessories 40526000...
Casset toilet will not pump water for flush
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
May 27, 2009 | Thetford Porta Potti
Thetford Porta Potti  Logo
1,447 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
