Question about Gaggia MDF Coffee Grinder
Broken Handle on Coffee Grinder
Got one of these crazy expensive Gaggia coffee grinders as a pres (
and somehow I manage to break off the little plastic handle which dispenses the ground coffee from its holding area
Any ideas on how to fix this??
btw- I have already tried the usual superglue/crazy glue stuff and the plastic won't stick together.
  • 833 Answers
Nice unit! Replace the part. Try
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Posted on Dec 03, 2007
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Platinum Vogue Built in Grinder
Just use the whole bean. Using pre ground coffee through your grinder will screw the blades completely.
However if you have a decaff option that allows you to put coffee directly into the brewer that would be ok........just dont put it into your hopper that feeds the grinder.
Mar 03, 2010 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Grinder blocked
Check the chute from the grinder to the brew unit.
Oct 06, 2009 | Gaggia Titanium Espresso Machine
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
181 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
