Question about Miscellaneous
Jd 3010 turns to the left by itself,leaks hyd. fluid from little valve below steering column that goes to brakes
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
Erm, fix the leak for a start, it's not eco-friendly and may cause you to have a serious accident ;)
Is the leak actually from the steering circuit?
You may have a worn hydraulics unit (can be replaced as a unit (second hand?)
Under what conditions does it turn left?
What wheel configuration do you have?
All the time, under braking?
Are the brakes binding.
Is it simply that the steering wheel is on the wrong spline (not centred)?
Has the steering been damaged (bent by collision)
Please supply more info
Posted on Jan 13, 2018
SOURCE: steering noise
I have a 2000 Mercury sable sedan and when I turn to the right a get a squeaking noise coming from
the rod that attaching to the outer tie rod, the sound is coming from the boot on the right side of the rack and pinon sterring?
Posted on Sep 21, 2008
chuck943
  • 783 Answers
SOURCE: high pressure power steering hose - one or two?
Here is a pic.
[IMG]http://i253.photobucket.com/albums/hh43/chuck943/DG1690A.gif[/IMG]
1 3A674 Power Steering Pump 2 3A714 Power Steering Pressure Hose 3 3C510 Power Steering Hose Bracket 4 3N824 Power Steering Pressure Switch 5 3504 Steering Gear 6 3A713 Power Steering Return Hose (Gear to Cooler) 7 3D746 Power Steering Fluid Cooler 8 3493 Power Steering Return Hose (Cooler to Pump
Posted on Feb 23, 2009
  • 66 Answers
SOURCE: brake fluid leaking out the back left tire area
you a have blown wheel cylinder replace it and the brake shoes bleed the system and your good to go
Posted on Jun 29, 2009
juncro
  • 467 Answers
SOURCE: Proportioning valve leaks brake fluid.
yes you must change same, in my experience i change it
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: Power steering goes out, turn off car and power
There is a recall on the power steering just call any GM place and tell the that you have a recall and would like to have it fixed and it won't cost you a dime!
Posted on Aug 22, 2010
Whining sound jd 4510 four wheel drive
accord to my books this tractor has a wet clutch transmission (12 speed) , first thing is to ck your fluid level in transmission , this is bit hard to reach on this one but is possible second obtain a small sample of fluid from transmission, have it tested , It can tell you alot , second you mention that hydraulic pump overloads engine with simple tasks like raise 3-point, this could be a stuck pressure relief valve due to yep you guessed it dirty filter (it bypassed itself) ck hyd fluid for proper level and clarity ohh and one more thing this tractor uses hyd pump for power steering (some others have 2nd pump for this) is it possible that noise is coming from that area , cus I have had to replace power steering valve on that model once for a loud Noise reason
remember if your gonna have a all hydro tractor save yourself a lot of grief and periodly wash shaft seals with water sure saves a lot of grief and leaks !!
Jun 21, 2014 | John Deere Garden
Bmw 850 csi hyd problem
replace is the only fix
Jun 09, 2008 | 1994 BMW 8 Series
I changed the entire steering column in my 92 s-10 and now have now brake lights at all no power going to the brake light switch itself and no left blinker but the right side works and turn the flashers on...
Check the brake light fuse. Check that one of the brake light fuse terminals has power at all times. Power for the brake lights goes from the fuse panel to the brake light switch, before the brake light wire goes into the steering column.
Nov 21, 2013 | Cars & Trucks
Poured brake fluid in power steering
Hey, If you got brake fluid into the internal workings of the gear,, you may have to have it rebuilt... brake fluid does a number on seals and o-rings...you have at least 4 seals and 3 o-rings...not to mention the 4 teflon rings on the valve body..if all you have is air in the line,.. it will work itself out..I would watch for oil leaks..... watch for the boots (long round black corrugated hard rubber) on each end of the gear filling with oil - they will swell up before they burst/leak.. - if this happens.. you will lose all steering... it will be harder than manual steering... to remove the air faster, just get in a large area and turn from full lock right to left over and over...and over and over.. it will work itself out.. IF there is a leak to the outside (you might be sucking air INTO the system)..and oil will be leaking out..
Aug 14, 2017 | Toyota Cars & Trucks
The brake pedal pulses when stepping on the brake with no steering wheel shake on a 98 Ford F150, rear ABS only. The ABS differential sensor has already been replaced. What could be causing this?
have you checked the rear brake rotors/drums for being warped ??
normally vibrations while braking are.. through the steering wh = front
thruogh brake pedal/seat = rear
good luck
Jun 15, 2011 | 1998 Ford F150 Regular Cab
99 Jeep grand cherokee steering column makes a clunking
If its a whining noise, check the power steering fluid level and fill if low, otherwise you may have a pump going out or a loose belt
Jul 29, 2009 | Jeep Cherokee Cars & Trucks
631 clark skid steer won't drive or steer the left side? the chain is still on the sprockets.
With all the hyd pressure released, need to unhook the 2 big hoses going to the hyd motor on the chain case on the left side and CAP OFF with fittings. Next start the machine and SLOWLEY move the travel control for the left side a little front and back, you should hear a loud growl from the hydrostat, showing that it is pumping under load. Dont do this long, but enough to test. No noise means the problem is in the hydrostat, possiably bad slipper plate, rotating group or both high pressure relief valves.If you have noise the problem is in the hyd motor. Good luck and be carefull!!!
May 09, 2009 | Bruder Cat Skid Steer Loader
Miscellaneous Logo
27 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
