Question about Dolphin Maytronics Diagnostic Robot Cleaner
Yellow tracks keep coming off enough to stop the motion of the dolphin
    President:
  • Dolphin Master
  • 1,378 Answers
Tracks are stretched out and need to be replaced. For a quote on do-it-yourself parts, contact us at www.arrowpools.net with your model and serial number.
Posted on Jul 31, 2009
The track belt keeps dislodging from brush roller wheel...is the an adjustment to tighten so that track belt remains secure to brush roller wheel?
No...once they are stretched out, usually caused by softening of the track material due to water chemistry issues, the only solution is new tracks.
For pricing infomation please contact us using the dolphin button along the bottom of our site at www.arrowpools.net.
John
Sep 11, 2011 | Dolphin Maytronics Advantage
I love my Dolphin Dynamic 342348BU47 I have had her for two years, her name is Daisy. One side of her track will not run. I turn her on she moves forward 6 inches then back 6 inches then stops. I have...
Check inside the side plate on the side that won't move for debris such as goggles or swim toys. If nothing is jamming the track the motor might be bad or the wheel tubes that connect the tracks together could be damaged so check those as well.
John
Jul 11, 2011 | Dolphin Maytronics Advantage
The light goes on and nothing happens. no sound at all. it was working fine two days ago. thanks
Try a self test...flip the unit upside down on your deck and plug everything in a turn it on. Within 15 seconds it should start moving the tracks and the progress thru several track direction changes with and without the impeller motor turning on. After 30-45 seconds of these motions it will shut off and at that point I would put it back in the water and it should work.
If it will not perform the self test or will not operate after the self test it needs service.
For a list of service centers or further troubleshooting assistance please contact Maytronics directly at www.maytronicsus.com or 888-DOLPHIN.
John
May 19, 2011 | Dolphin Maytronics Diagnostic Robot...
On starting, tracks roll one way for a few seconds, then reverse for a few seconds then stops with no further movement. Pump impeller does not move during this time. Impeller can be rotated by hand. No...
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 14, 2010 | Dolphin Maytronics Diagnostic Robot...
Can I get the yellow tracks for my dolphin advantage without sending it back to Maytronics. It works great but the tracks are beginning to slip after extended use.
Yes you can...
To purchase them contact us thru our site at www.arrowpools.net and we can confirm which version of track you have and quote the price to ship them to you.
John
Jul 09, 2010 | Dolphin Maytronics Advantage
Change tracks
Remove all twelve screws inside the case (6 per side), remove the handle screws and pull off the handle, then remove the side plates. Once these are out of the way, remove the old tracks and install the new ones. Reassemble in reverse and you are done.
John
Jun 13, 2010 | Smart Pool Inc Dolphin Diagnostic...
My Dolphin will run for a couple of minutes then quit. The power supply light stays on but robot stops. When I try to turn the tracks one direction is free the other direction catches. I think one track...
We sell them. You should replace both at the same time top keep the tension equal on both sides. For pricing, please use the contact button found on our site at www.arrowpools.net or call us at 734-285-5700 7a - 6p EDT.
Jun 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Cut cord
Yes but it is going to be tricky. You will need to open up the power supply and pull the black and white wire from the cable socket. Note what position they were connected to for reassembly later. Now strip the cable back enough to get to the wires inside and connect them white to white and black to black. Turn the dolphin upside down (tracks towards the ceiling) and turn it on. It should go thru a series of motions lasting about 30 seconds and then stop. If it does it has just passed a self test and will likely work in your pool. For parts or to have this test and others performed in a service center contact us thru www.arrowpools.net using the dolphin button along the bottom of the page.
John
Apr 26, 2010 | Dolphin Maytronics Advantage
Dolphin will go fwd for so long and then stop,
It is probably a motor issue. For information on servicing a Dolphin please complete our dolphin service form available at www.arrowpools.net.
Sep 03, 2009 | Dolphin Maytronics Advantage
Stopped working
Try a self test...Flip the unit upside down on the ground, tracks 'up towards the sky' and trun it on. It should run for about 30 seconds during which it will cycle through various track and impeller motions.
If it completes the test, try it in the water again.
If not, contact us at www.arrowmotor.net for service arrangements or parts. You can also try Maytronics direct at www.maytronicsus.com.
Jun 01, 2009 | Dolphin Maytronics Diagnostic Robot...
Dolphin Maytronics  Diagnostic Robot Cleaner Logo
124 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
