Question about HP Officejet Pro L7680 All-In-One Printer
I had a paper jam, and pulled the paper through. Now, one of the rollers is stuck in the up position. How can I fix this?
  • 110 Answers
Clean the dust from your cattridge and replaced it again.
Posted on Jul 30, 2009
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Tip
Attention To Solve Paper James Of Transfer Roller
Sometimes you may be able to solve the common problems yourself in your laser printer if you know a little about the structure inside it, such as paper jams due to improper positioning at the transfer roller. Before the printing process at the fuser assembly, the paper has to pass through the transfer roller inside a laser printer that is used for transferring toner from the cartridge drum onto the printing medium. It works with opposing electrical charges to pull the toner particles.
Paper jams usually occur at the image transferring process, if the paper get stuck at the transfer roller, just open up the side cover and pull out the paper gently, don't touch roller surface without gloves when hold the ends of the roller, as the sweat and oil of your hand can pollute and damage the surface material.
on May 05, 2017 | Office Equipment & Supplies
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Model No MFC7420 Paper gets stuck through heat roller - constantly opening up machine and pulling paper out. Very annoying. Can this be resolved? Or is it an expensive fix
normally if the paper is jam after the heat roller and before the exit part.. the cause of the problem is the wore out Paper Eject Roller.. it's not an expensive fix..the cost probably will between US20 to US30..
But if the paper get jam before the roller..you might need to check the heat roller finger...if that is damaged.. it would cause paper to jam as well...
Jun 27, 2010 | Brother DCP-7030 Digital All-in-One Laser...
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Paper jam indicator will not go out...no paper jam found
Hello sir; sometime paper jam right in the begining when it try to pick up the paper from the tray, you not going to see the paper, only thing you can do is pull out the tray reset the paper and push back again, if still jam, then you better clean up the paper pick roller.
Oct 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon imageRunner 3200n paper jam in the fixing unit
Hello sir;pull out fixing unit check out the paper sensor that located at the paper exit side,let it move freely.
Jan 10, 2009 | Canon imageRUNNER C3200 Copier
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
HP Officejet Pro L7680 All-In-One Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
