Question about Homelite Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
  • Anonymous Mar 18, 2014
    chain won't move around
    Scholar:
  • 97 Answers
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Posted on Jul 30, 2009
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Apr 03, 2016 | Homelite Garden
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
How do you mix 50:1 petrol to oil uk ratio
50 parts gas to 1 part oil = one imperial gallon = 160 imperial ounces (fluid) 50 divides into 160 / 3.2 times since a std 2 cycle oil container is 7 imperial ounces you'll need two and four tenths containers of oil for a gallon of petrol ???
Jun 05, 2014 | Homelite Garden
I brought a brand new homelite 33c-csp 3314 and my wife threw the manual out or i lost it ,how much chain and bar oil do you put in the oil part? i cant open pdfs cause somethings wrong with that thank...
Hi, basically you fill it up every time you fill up with two stroke fuel as it uses about 3/4 of a tank of bar oil to a tank of fuel. Regards Phil.
Aug 11, 2011 | Homelite Garden
What fuel does the csp 3314 use? I bought this chainsaw second hand and i am unsure what fuel to put in it. Thanks in advance for any assistance Kelly
You need to mix 3.2 oz of 2 cycle oil to 1 gallon of gas. Some may disagree but a 40:1 ratio is better than a 50:1 mix. It gives more oil in the mix to keep the cylinder/piston lubricated. Any less and you will burn up the engine. With this new mixture you may need to get a professional to readjust the carburetor to this new mix.
Sep 25, 2009 | Homelite Garden
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
May 22, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Problem oil doenst arrive at chain Homelite model CSP 4016 40cc
Remove your bar and free rev the engine, check that the oiler hole is pulsing and free from debris.
Feb 22, 2009 | Homelite Garden
Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
463 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
