Question about Roper Washing Machines
I was washing a load of clothes washer got off balance. No longer will spin or aggitate. water will come on thats it. is there a safety switch? I have model # RAS7133RQO
    Scholar:
  • 61 Answers
The belt may have fallen off due to the abnormal load, check that first.
Posted on Jul 30, 2009
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Maytag Bravos MVwX500XW0 Top Load Washer is not spinning
Check the inbalance/lid switch for continuity.Ck speed selector switch (if any)the water level and water temperture switches for proper opreation.NOTE:If any of the selector switches on the console are only poartially pushed in,it may cause improper function.I do not know how old your washer is.TEST LID SWITCH FIRST.If above does not solve,ck timer circuits for continuity.Get ready for this:there is to much to ck with out been there.is motor buzzing,test capacitor,washer spins but does not agitate,ck the agitator splines if they are not rhe problerm,the transmission might be the problem.GOOD LUCK.FYI I own Whirlpool washer and dryer and I repair my own,I prefer KENMORE/WHIRLPOOL/ROPER PRODUCTS because they are easy to repair and parts are not as high priced.
Sep 15, 2012 | Maytag Bravos X MVWX500X 4.3 cu. ft....
Washer doesn't spin GE WCSR2090
does it aggitate??
the safety button is most likely broken, you can see the small hole where the figer pushes down to stop the spin cycle, if the washer does not aggitate, then most likely it the safety switch.
get it replace, or bypass(not adviseable) but only when you need it,
Water that doesnt move tend to get stinky fast!
Oct 29, 2010 | Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator or tub not spinning after move from detroit to LA
IT SOUNDS LIKE YOUR DRAIN HOSE IS LOWER THAN YOUR TUB WATER LEVEL BE SURE THAT YOUR DRAIN HOSE IS ABOVE THE TUB LEVEL.GLAD TO BE OF SERVICE
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
