Question about Garden
My 14hp 42" craftsman lawn tractor will initially crank over and run for a few seconds then it quits. the only way I can keep it running is if I completely choke the carb by putting my hand over the intake. and then it runs real rough and has no power. I think its getting too much air and not enough fuel. any suggestions?
    Scholar:
  • 125 Answers
Sounds very much like a blocked main jet.
Pull the bottom of the carby while holding your hand cupped under it.(turn fuel off first)
If you find water drops, that is your problem.
If not,
Find the main jet.
Usually brass and in the center.
Look straight up into the carby and unscrew it with a smallish flat blade screwdriver.
Hold it up to the sun, you should be able to see a nice clean little hole.
If it is blocked, clean it with a wire from a wirebrush. Be gentle, if you damage it, you will never get it to run nice.
Clean every part carefully before re assembly.
Turn the fuel on and mow, mow, mow. :)
Posted on Jul 30, 2009
  • 162 Answers
Check yer carb adjustments...
high n low as well as idle
My 42 in Craftsman Tractor will not start. It normally runs great. I went to start it the other day and it ran for about 5 seconds before shutting down. It felt like it was getting no fuel. Any...
try and run it with the gas cap loose the vent could be plugged also see if it cuts out while keeping you foot on the brake and its just a bad safety switch shutting it off
May 29, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
Jan 12, 2018 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 550 brand new mower wont start
SONDS LIKE A FULE PROBLEM IT MAY NEED THE CARB CLEAND MAY HAVE BAD GAS
Oct 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Starts quits then starts after a few min
Have you checked your fuel filter? it may be clogged or contain water, which will limit flow of the fuel. This would be simplest to relace. Otherwise I believe it to be a carb problem.
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
