Question about Sony Cyber-shot DSC-W70 Digital Camera
DSC-W70 doesn't recognize full capacity of (Sony) 8GB Memory card
I upgraded recently from a 2GB memory card to a 8GB one. However I realized that the capacity (eg. for movies) hasn't increased in the same amount as expected; instead it merely (roughly) doubled, instead of around 4 times more.
Does a firmware update solve this problem? If yes, where can I get a (trustful) one.
Thx in advance for any help or suggestion,
M. (Austria).
  • 10,594 Answers
DSC-W70 hardware does not support 8GB memory stick.
Please use maximum 2 GB memory stick in this camera.
Posted on Jul 30, 2009
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Memory card problems DSC-W70
Format memory card through format option in camera menu so camera recognize it properly and if memory card has not been formatted then it seems defective memory card, check it in another camera for confirmatiion.
Nov 19, 2009 | Cameras
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
Can I use a 8GB memory card in my sony C902
The Sony Ericsson C902 does support up to 8GB memory card.
Aug 30, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Memory m2 card 8gb
hi
the solution 2 ur problem is that ur fone supports memory only upto 2gb.
so i think nothing can be done else exchane ur card for a 2gb card.
i hope ur problem has been rectified
all the best
Mar 10, 2009 | Sony Ericsson w580i Cellular Phone
Memory card capacity
BY INCRESTING MEMORY FROM LOW TO HIGH EVEY PHONE'S PERFORMANCE WILL BECOMES DOWN. THERE IS NO ALTERNET FOR IT.
BUT DONT WORRY A HIGHR MEMORY WILL NOT REDUCE YOUR PHONE'S PERFORMANCE VERY LOW. IT EFFECT VERY LIGHT DECREAMENT IN PROFORMANCE.
DONT WORRY JUST UPGRADE YOUR MEMORY. JUST DO IT.
REGARDS
KETAN PATEL
Feb 11, 2009 | Sony Ericsson P990i Cellular Phone
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Micro card
When I bought the phone I wanted to use a bigger Memory card. I was told it will only recognize 2gb. The booklet that comes with phone says the same thing, so would assume that is why it says full. Assuming of course youre trying to use more than 2gb at the moment.
Jun 05, 2008 | LG KU990 Viewty
Sony Cyber-shot DSC-W70 Digital Camera Logo
283 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
