Question about Lands Phones
I am looking for a lt terraneo install manual for a i way door entry intercom
Try www.alarmfix.co.uk
Posted on Feb 02, 2010
I need a wiring or instalation diagram for 03 silverado
Download manual from the attached link: https://www.gmupfitter.com/publicat/2004_BB/2003_Beyond_LD_Electric_CK.pdf
http://alarmsellout.com/support/diagrams/vehicle/CHEVROLET%20SILVERADO%201988-2005.pdf
This may help:
http://www.automotivetroubleshootingsecrets.com/2003_Chevrolet_Silverado_1500_4.8L_No_Start_Stall.html
This may help:
2003-2006 Chevrolet Silverado Wiring Diagram:
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2003-2006 Chevrolet Silverado . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 BROWN (+) @ IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) GRAY/BLACK (-) @ BCM, BROWN PLUG, PIN B2, SEE NOTE #3 PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL POWER LOCK SEE NOTE #1, (for BASE MODEL TRUCKS, SEE NOTE #4) POWER UNLOCK SEE NOTE #1, (for BASE MODEL TRUCKS SEE NOTE #4) DOOR TRIGGER GRAY/BLACK (-)(DRIVERS) and BLACK/WHITE (-)(PASSENGER), SEE NOTE #5 @ EACH DOOR MODULE, IN EACH DOOR DOMELIGHT SUPERVISION GRAY/BLACK (-) @ BCM, BLACK PLUG, PIN E, SEE NOTE #3 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK/YELLOW to BLACK (-) @ STEERING COLUMN HARNESS TACH Any wire NOT, PINK, BLACK or BROWN (AC) @ IGNITION COILS or FUEL-INJECTORS WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER, PIN A2 BRAKE WHITE (+) @ BRAKE PEDAL SWITCH FACTORY ALARM DISARM LT. GREEN (-) @ DRIVERS DOOR MODULE, IN DOOR, BLACK 26-PIN PLUG PIN 15 ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH EXTRA INFORMATION NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, if you are using a REMOTE STARTER ONLY, use the 791. IF you are installing a REMOTE STARTER with KEYLESS ENTRY you MUST USE the INTERFACE BYPASS MODULE, Part # DB-ALL or XK09, EITHER Bypass will do the Anti-theft and Keyless entry. If connecting a keyless entry only you can use the GMDL-BP. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located under the Drivers Side of the dash, the BCM has 6 plugs on it, with the PURPLE plug on the back. NOTE #4: On BASE model truck the DOOR LOCK INTERFACE MODULE is not necessary, the LOCK wire is a LT BLUE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B5, and the UNLOCK wire is a WHITE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B10. NOTE #5: On BASE Model trucks, the Door Trigger wires are @ the BCM, LT BLUE PLUG, PINS B4 and A5. On 4-Door Trucks the LEFT REAR Door is a LT BLUE/BLACK (-) PIN A3 and the RIGHT REAR Door is a LT GREEN/BLACK (-) PIN A2, located in a PURPLE PLUG at the BCM, use all 4 wires and diode isolate when installing an alarm system.
2011-03-28_044351_brakes_lamps_circuit_2003_2500_siverado-dfydxumns33ohqc3bsmt22yf-2-8.gif
collection-fuel-2003-chevy-silverado-wiring-diagram-estimation-information-standard-work-therefore-straight-swapped-dfydxumns33ohqc3bsmt22yf-2-34.jpg
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-53.png
sensor-primary-2003-chevy-silverado-wiring-diagram-fuel-pump-plugs-solid-conductors-important-looking-more-channels-dfydxumns33ohqc3bsmt22yf-2-76.png
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-151.png
Apr 16, 2017 | Cars & Trucks
Tip
Affordable Locksmith Company Las Vegas NV 800-779-8530 Locksmith In Las Vegas NV...
Affordable Locksmith Company Las Vegas NV 800-779-8530 Locksmith In Las Vegas NV Car Lockout- Las Vegas NV
24 Hour Locksmith Las Vegas NV provides fast, reliable, professional 24 Hour 24 Hour Locksmith Las Vegas NV services at extremely competitive rates. At 24 Hour Locksmith Las Vegas NVs we stand behind our workmanship - 100% client satisfaction guaranteed. At 24 Hour Locksmith Las Vegas NVs we have a fully equipped mobile machine shop available 24 hours a day 7 days a week, we service most major lock brands and associated door hardware, including the brands we do not sell.
http://global-locksmith.com
At 24 Hour Locksmith Las Vegas NV we offer fast, professional and experienced locksmith services. Our technicians are equipped with the latest modern technology and are available 24/7 at your request.
24 Hour Locksmith Las Vegas NV provides services such as Residential Locksmiths, Specializing in:Fast lock out services, Locks installed & Repaired, Re-keys & Master Key Systems, Window Guards & Grills. Automotive Locksmiths, Specializing in: High Security Cylinder Changed & Re-Keyed, CCTV, Card Access Control, Intercom, Panic Devices, Safes Combination Change, Electronic Keypad and Keyless Entry. Commercial Locksmiths, Specializing in: Fast
Lock out services, Replace & Repair lost & Broken Keys, Precision Key Cutting Services for all make And models on site.
We provide 24/7 locksmith services such as:
Commercial Locksmithing, Specializing in: Lock Out, Deadbolt Locks Changed, Installed & Repaired, Re-keys & Master Key Systems, High Security Locks Systems, Intercom Systems Repair & Installation, Fire Proof Panic Bars Repaired & Installed, Peephole Installation.
Automotive Locksmithing, Specializing in: High Security Cylinder Changed & Re-Keyed, Closed Curcuit Television CCTV, Card Access Control Systems, Panic Lock Devices, Safes,Windows,Glass Doors & nvtes, Padlock, Combination Lock, Electronic Key, Magnetic Keys, Electronic Keypad and Keyless Entry, File Cabinet & Lock Picking.
Residential Locksmithing, Specializing in: keyless Entry, Key Cutting & Key Replacement, Emergency Vehicle Opening, Emergency Trunk Opening, Extraction of Broken Keys Locksmith, GM VAT Keys Duplication, High Security Vehicle Key Duplication Locksmith, New Ignition key and Transponder Chip Key.
RESIDENTIAL LOCKSMITHS COMMERCIAL LOCKSMITHS AUTOMOTIVE LOCKSMITHS
Deadbolt Lock and Key Replacement Car Lock Out
Knob Installation Window Lock Replacement Vehicle Locksmith
Cabinet Lock Replacement Re key and Master Key Install Lost Transponder VAT Keys
Closet Locksmith Safe Lock Repair & Install Automotive Lock Repairs
Safe Lock Repair & Installation Office Lock Replacement Ignition Key Replacement
Desk Lock Repair Replace Mailbox Key & Lock Automobile Lock Out
Master Key Installation Industrial Key Duplication Motorcycle Ignition Repair
Master Key Cutting Office Door Lock Picking Car Lock Out
High Security Cylinder Locks Replace Lost Office Keys Panic Lock Devices
House Lockout / Open Door Locks Store nvte Pas Locks Opened Combination Locks Opened
nvrage Lock Replacement Office Door Lock Out Emergency Trunk Opening
High Security Locks Opened Deadbolt Locks Changed Emergency Vehicle Opening
Domestic Locksmith Re keying Master Key Systems Key Cutting
Extraction Of Broken Keys Electronic Keypads Car key Replacement
Peephole Installation GM VAT Key Repair and Install Transponder Chip Key
Intercom Systems Repair & Install Keyless Entry Magnetic Keys
locksmiths Las Vegas NV
locksmith in Las Vegas NV
locksmiths in Las Vegas NV
locksmith Las Vegas NV
sandy springs locksmith Las Vegas NV
a locksmith Las Vegas NV
auto locksmith Las Vegas NV
Las Vegas NV locksmith services
Las Vegas NV locksmith reviews
emergency locksmith Las Vegas NV
commercial locksmith Las Vegas NV
car locksmith Las Vegas NV
on Apr 21, 2010 | Computers & Internet
Tip
LOCKSMITH DC 800-779-8530 Locksmith Washington DC Car Lockouts - METRO...
LOCKSMITH DC 800-779-8530 Locksmith Washington DC Car Lockouts - METRO AREA,NW,NE,SE,SW,DC,VA,MD
http://www.global-locksmith.com
Phone: 202-683-6000
Email Address: service@global-locksmith.com
Locksmith Washington DC provides fast, reliable, professional 24 Hour Washington DC Locksmith services at extremely competitive rates. At Washington DC Locksmiths we stand behind our workmanship - 100% client satisfaction guaranteed. At Washington DC Locksmith we have a fully equipped mobile machine shop available 24 hours a day 7 days a week, we service most major lock brands and associated door hardware, including the brands we do not sell.
At Washington DC Locksmith we offer fast, professional and experienced locksmith services. Our technicians are equipped with the latest modern technology and are available 24/7 at your request.
Washington DC Locksmith provides services such as Residential Locksmiths, Specializing in:Fast lock out services, Locks installed & Repaired, Re-keys & Master Key Systems, Window Guards & Grills. Automotive Locksmiths, Specializing in: High Security Cylinder Changed & Re-Keyed, CCTV, Card Access Control, Intercom, Panic Devices, Safes Combination Change, Electronic Keypad and Keyless Entry. Commercial Locksmiths, Specializing in: Fast
We provides 24/7 locksmith services such as:
Automotive Locksmithing, Specializing in: High Security Cylinder Changed & Re-Keyed, Closed Curcuit Television CCTV, Card Access Control Systems, Panic Lock Devices, Safes,Windows,Glass Doors & Gates, Padlock, Combination Lock, Electronic Key, Magnetic Keys, Electronic Keypad and Keyless Entry, File Cabinet & Lock Picking.
Knob Installation Window Lock Replacement Vehicle Lockmsith
Cabinet Lock Replacement Rekey and Master Key Install Lost Transponder VAT Keys
Closet Lockmsith Safe Lock Repair & Install Automotive Lock Repairs
Master Key Installation Industrail Key Duplication Motorcycle Ignition Repair
House Lockout Open Door Locks Store Gate Pas Locks Opened Combination Locks Opened
Garage Lock Replacement Office Door Lock Out Emegrency Trunk Opening
Domestic Locksmith Rekeying Master Key Systems Key Cutting
WASHINGTON DC MONTGOMERY VILLAGE GERMANTOWN GAITHERSBURG ROCKVILLE OLNEY POTOMAC SILVER SPRING COLLEGE PARK GREENBELT BETHESDA BOWIE SUITLAND STERLING RESTON CHANTILLY OAKTON CENTREVILLE FAIRFAX BURKE ANNANDALE ARLINGTON ALEXANDRIA SPRINGFIELD WOODBRIDGE
Locksmith Washington DC | Washington DC Locksmiths | 24 hr Locksmith Washington DC
©All Rights Reserved. http://www.washingtonlocksmithdc.com | service@washingtonlocksmithdc.com
locksmith washington dc,replacing lost car keys,transponder keys,locked door,locks,rekeying locks,emergency locksmiths dc,24 hour locksmiths dc,24 7 locksmit dc,best locksmith dc,professional locksmith dc,home locksmith dc,24 hours locksmith,car locksmiths,locksmith key,locksmithing,locksmith keys,emergency locksmith,24hr locksmith,auto locksmiths,locksmiths,automotive locksmith,locksmith service,the locksmith,the locksmith,locksmith city,locksmith supplies,a locksmith,american locksmith,find a locksmith,locksmith services,mobile locksmith,local locksmith,auto locksmith,locksmith cost,locksmith prices,car locksmith,24 hour locksmith
locksmiths dc
locksmith in dc
locksmiths in dc
locksmith dc area
locksmith dc
affordable locksmith dc
emergency locksmith dc
locksmith
24 hour locksmith
locksmith prices
locksmith business
locksmith cost
locksmith tool
auto locksmith
available locksmith
usa locksmith
find locksmith
area locksmith
locksmith course
locksmith supply
locksmith training
mobile locksmith
locksmith services
local locksmith
locksmith supplies
find a locksmith
reliable locksmith
the locksmith
a locksmith
locksmith service
locksmith city
american locksmith
master locksmith
certified locksmith
locksmith locator
I would like to know how to transfer a call from one phone to the other on a cordless versatis p100
During an external call:
1. Press <MENU> and <UP/DOWN> to select INTERCOM.
2. Press <OK> to select the desired handset to intercom with.
3. The external call is put on hold automatically and the called handset
rings.
4. Press <TALK ON> on the called handset to establish an internal call.
5. Press <TALK OFF> on the calling handset or put the calling handset on the charging cradle to end the current call with the external party.
6. The external call is transferred to the called handset.
Jul 14, 2014 | Uniden Cordless Phone
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
I need to change my door codes on my 92 nissan maxima
1991-94 Nissan Maxima key less entry reprogramming:
1. The *original code found on the gold box under the glove compartment by the left kicker panel
(there should be 3 sets of codes on the gold box the code u want begins with the letter F and has 7 digits.) (_EXAMPLE_ F# S1234567 )
2. Close and lock all of the doors,
enter the 7 digit code ( make sure you have your key in your pocket not inside any key hole).
3. Once the code is entered correctly you will hear a long beep.
While the beep is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps)
>>>>>>>>>>>>>Do not touch anything until the beeping stops.
________After the beep is over______
4. T
ype: S or ST (Clear) and the New 4 digit code and the door will open automatically.
~~~~~~~> NOW YOUR DONE YOUR CODE HAS BEEN RESET.
5. If you forget your new code. Just enter the original one and start all over.
Its really simple I hope it helps...............
Mar 21, 2011 | 1993 Nissan Maxima
Problem with KXTDA50 CO 4 Connected to Gate entry system
you can increase the timer that the system checks for dial tone... but you BEST bet would be to put the doorking into Intercom mode
May 26, 2009 | Panasonic KX-TDA50 Phone
Lands Phones Logo
2,059 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
