Question about JVC KD-GS611
The cd player plays the first 10 or so tracks fine but then there is no sound on the last half of the disk.
I haven't solved it but I can't afford to pay for an answer. Thanks anyway,
Posted on Aug 02, 2009
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
I have a small new Philips Music system which plays CD as well as FM. It is brought from Poland with a guarantee last month. The problem is that CD'S get stuck after about 25 minutes of playing. ...
Did you get a small piece of single wire with the system. That's the FM antenna. Connect that at the back of the music system labeled FM Ant: and it should solve your problem. Just check in the auto tune mode does the radio stop at the station number correctly and if the stereo indicator light up.
When the player gets stuck, if you put another CD will it play the new CD play for 25 minutes ?. If so try playing the last track of a CD after a cold start. It it does not play the last track on a cold start , you have some physical blockage/damage on the lens rail after half position.
Mar 07, 2011 | Philips Audio Players & Recorders
Cd player won't play first track
there is a cd writen problem with the 1st track.......
Nov 18, 2009 | Audio Players & Recorders
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Some dvd's won't play.
When you get a whirring sound, some click and disk not engaging, that is because lens cannot read the inital track on the CD/DVD.
This is either because disks are scratched , dirty or ruined by light and heath, or because the lens is dirty.
Try using a lens cleaner like the ones here.
If that does not work, then the unit must be taken apart and the lens cleaned with cotton buds and isopropyl alcohol.
See :
How to Clean the Laser Pickup Lens on your DVD Player
Feb 17, 2009 | Samsung DVD-V5500 DVD Player/VCR
Car Audio & Video Logo
43 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
