Question about Maytag Heating & Cooling
My maytag 14,500 BTU window air conditioner with digital controls was working fine for several months now when I set the temperature the air conditioners temperture setting will rise by itself untill the compresser kicks off. I lower the temperature setting and it goes back up by itself.
SOURCE: Problem with capacitor of air conditioner?
the ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
Posted on Dec 29, 2007
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
skrbin
  • 121 Answers
SOURCE: what startup surge Watts required for 5000btu Air Conditioner
1.5kW
Posted on Feb 17, 2009
  • 659 Answers
SOURCE: No installation manual for new air conditioner
Here you go...........
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAS257S2A&User=&Search=Search
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: DeLonghi A120 12,000 btu ar conditioner Leaks
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Posted on Jul 26, 2010
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Not cooling - M7Y15F2A-B
have you done adjusting the thermostat settings & changing the mode settings..?
Jul 27, 2008 | Maytag M7Y15F2A Air Conditioner
Timer for Maytag 8000 btu digital window air conditioner If i put my ac on a timer (it doesent have a built in one) it wont turn on unless i press the on button. Is there anything I can do to get it to...
Not much you can do with it being a digital control ,power needs to stay on all the time. There are ways around it but it is a chore re wiring to make it work.
Aug 19, 2013 | Maytag M6X06F2A Air Conditioner
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Maytag window airconditioner, temperature setting changes automatically gradually from 73 to 88 degrees. Unplugged it, started it again, works for about 30 minutes fine, then changes temperature again.
You have the sleep mode set, which gradually increases the temperature setting( Usually 1degree each half hour until the off time is reached), so turn off sleep mode and it should be fine
Apr 19, 2010 | Heating & Cooling
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
I have a maytag room air conditioner that needs compresser
the cost of a compressor is significant. you will be money ahead to buy a new air conditioner that will use less power and cool better.
Jun 19, 2009 | Fedders 14,500 BTU Electronic Control Room...
Maytag on the out
Our maytag window air conditioner (12,000 BTU; model#M^Y12FB-J
changes the temperature on its own. And it always goes up in temperature as high as 88 degrees and of course then it isn't cooling at all. I checked to see if frost or ice had collected on the copper tubing but it hasn't. I unplugged it for 1 hour to see if it would reset but that didn't help. It is about 2 years old. When it first happened, it seemed that if I used the remote it would stay at the right temp., but now it doesn't matter. It's hot and humid in my house - help!
Susie
Jul 17, 2008 | Maytag M6Q10F2A Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
