Question about Kitchen Ranges
Oven not working
The oven stopped working , The display says Err stuck key. F2EO. I have a kitchenaid, F2EO Stuck Key Error. Model #/serial # were removed. I'm guessing by visual it's model #YKESS907SP. I've ordered a part Stove/Oven/Range Switch - 9761566. Currently I'm awaiting it's arrival.
  • 2 more comments
  • Anonymous Dec 09, 2007
    I have a Whirlpool, F2EO Stuck Key Error. Model #/serial # were removed. I'm guessing by visual it's model #GERC4110PS.
  • Nauticnerd Dec 10, 2007
    Help, what did u have to do to fix the error?
    thanks.
  • Anonymous Apr 27, 2008
    the screen sayd stuck key error F2 E0
  • nutra Oct 25, 2008
    I have a Whirlpool Gold 18 months old. I was running the self-clean cycle (3 time I run it since I've had it). Half-way through, it starts beeping AND this message appears: Stuck Key F2E0
    What does it mean? Sears brushed me off saying the 1 year warranty is up. We can help you out by sending a technician and charging to tell me what the code means! Why do I keep buying from Sears!
    Assistance would be appreciated.
    Mod# GERC4110SS-0
    Ser# RT1710593
    Type P30
    Eric
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Posted on Sep 05, 2007
codfish124
  • 36 Answers
SOURCE: range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Posted on Dec 13, 2008
SOURCE: Error
f2eo stuck key sign
Posted on Dec 22, 2008
reyjoshua07
  • 1157 Answers
SOURCE: KitchenAid range ProLine series kesv908
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 22, 2011
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
Hope it helps.
Sep 21, 2011 | KitchenAid Kitchen Ranges
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Oven not working
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
218 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
