Question about Hitachi 61SDX01B 61" Rear Projection Television
Keep repairing a 8 yr old TV
This will be the third time, I've had a repair man come out and fix a convergence circuit failure on my Hitachi 61 inch projection tv.
Is it worth paying to have this same problem fixed or should I purchase a new set?
  • 167 Answers
If the TV still has a good picture then yes. Have the Tech replace the IC's with the Sanyo Type as they are a better quality IC. They cost about $30 each as opposed to the generic for $10 each. He should also make sure there are no resistors in the circuit that may have changed value.This could cause the IC's to go bad prematurely.
Posted on Jul 30, 2009
Picture is off the top of the screen everytime it is turned on. If you turn it on and off several times(3-13) it will become watchable. Sometimes it is off the bottom, or both sides are concave. Or it will...
Its a rather old set to be fixing, if off at top or bottom=vertical deflection problem, if sides are concave pin amp circuit---the fact you can turn it on/off several times etc suggests to me maybe bad solder connections somewhere in those circuits.
AS old as this set is keep in mind a lot of the parts for it are no longer available so be careful about spending a ton of money to fix it.
Dec 14, 2012 | Sony KP-61V35 61 in. Rear Projection...
IS it worth fixing a 7 yr old tv with convergence problems?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2011 | Hitachi 51F500 51" Rear Projection...
Hitachi 61UWX10B 61 in. Rear Projection Television, See double image, Magic focus doesn't fix
  • Screen looks 3D
69189a5.pngSOLUTION
Mar 06, 2011 | Hitachi 61UWX10B 61" Rear Projection...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model #43fdx20b, How much is cost to repair?
Hi, i'm a technician in florida.
The cost for me to referb a deflection assy is
289.50 plus tax.
i'll give you a nice tip...sometimes the convergence circuit temps to load the power supply...try to fix the convergence circuit first...then see if that fixed it.
convergence ic# stk392-110...try the stk392-120, they are more reliable...my e-mail bhzrdg@yahoo.com
Oct 08, 2009 | Hitachi 61SWX10B 61" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Rca 61 inch tv
that "pop" was the flyback transfor, a resistor, or a capacitor bloweing up. if your not a technician this is considered a circuit repair and ther are no serviceable parts inside this set for you to replace without the proper tools , service manuals, and schematic diagram. Sorry man your gonna need a serfvice pro to help ya with this repair. Good Luck
May 24, 2006 | RCA P61927 61" Rear Projection Television
Hitachi 61SDX01B 61" Rear Projection Television Logo
221 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
