Question about HP PhotoSmart 7550 InkJet Printer
My HP 7550 suddenly quit pri9nting. Cartridges are adequately full, carriage seems to move and mimic printing but no output. Print test page runs thru cartridge moves but ejects plain piece of paper with absolutely NO ink released. No error messages or codes? Need Help
  • HP Master
  • 13,433 Answers
Try performing print head cleaning from the hp toolbox or start -> printers and faxes -> right click on your printer -> printings preferences -> maintenance or similiar.
Print head cleaning, and print head alingment / nozzle check.
If that doesn't help reseat the cartridges, if you have another set of cartridges try them. Are these old cartridges? possibly dryed up?
Remove the cartridge from the printer if the print-head cleaner doesn't cause ink to flow. Soak it in a bowl or sink filled with enough warm water to immerse the print head nozzles, long enough to see ink beginning to dissolve and flow into the water. Alternately, you can soak a cloth in warm water and use it to clean the nozzles until you see ink begin to flow.
Thoroughly dry the nozzles with a soft, lint-free cloth once the cleaning process is complete.
Replace the cartridge into the printer and run the printer's print-head cleaning utility.
Repeat the cleaning procedure if the cartridge still doesn't print. Reinstall and once again run the print-head cleaning utility.
Posted on Jul 30, 2009
After changing ink carteidge it keep saying align cartridge, what can i do to erase this error?
It is my pleasure to guide you.
These steps will take you through the process of replacement and alignment.
HP PSC 2175 All-In-One InkJet Printer
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2. After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3. If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
4. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6. Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7. Close the print-carriage access door.
align the print cartridges
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge.
Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
1. Press Setup.
2. Press 2, then press 2.
This selects Maintenance, and then selects Align Print Cartridges.
I found the manual for this printer, if you do not have it already. If you wish to download it click or copy this link
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 15, 2011 | HP PSC 2175 All-In-One InkJet Printer
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Paper jam cleared but wont start
  1. Unplug the power cable.
  2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
    • If the carriage moves freely, skip to Step five .
    • If the carriage does not move, continue with the next step below.
  3. Remove the print cartridges.
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Remove the rear access door.
  7. With your fingers, rotate the rollers "up" three full rotations.
  8. Push the rear access door back into the printer until it snaps firmly into place.
  9. Replace the print cartridges.
  10. Plug the power cable into the HP All-in-One.
  11. Turn the power on.
Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
  1. Reload the printer with plain paper.
  2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
Cartridge jam displayed
Follow these instructions: Moving the carriage
  1. With the all-in-one turned on, open the print cartridge access door. The print carriage might try to come to move into the access area. Allow it to move to that position if it does.
  2. Without turning off the all-in-one, disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the parts to be moved by hand and to reset the paper feed mechanism.
  3. Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
  4. Verify that the print carriage can move freely across the width of the all-in-one by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and reconnect the power cord.
  6. Press the On button to turn on the all-in-one.
  7. Print the self test from the menu to check the functionality of the product by following these steps:
    • Press Setup , press 2 , and then press 6 in sequence. (The printer should be in ready mode.)
  8. If the self test printed in the step above, then try to print from the computer to see if the issue is resolved.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Step two: Plug the product directly into a wall outlet Verify that the product is properly connected to a suitable power source by following the instructions below.
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. Try the print job again to see if this step resolved the issue.
    • The above was from this HP doc:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=34246&product=441125
How to clear error message from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&lc=en&dlc=en&cc=us&lang=en&rule=34246&product=441125
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | HP Officejet 5610 All-In-One InkJet...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
How to change cartridgeon HP desktop D4160
from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
52 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
