Question about Toshiba Satellite A75-S209 Notebook
Will run after you retart it several times and then freezes up
    Problem Solver:
  • 8 Answers
Remove any new installed programs or drivers.
run a malware scan
use system restore
If the pc runs hot, check if it has good ventelation and the fans are spinning, good to use compressed air to blow out dust from the fans check if the pc has been overclocked and make sure to set to run at recommended speed.
Posted on Jul 30, 2009
How can i replace the crankshaft position sensor bank1 timing retarted
The timing would not be retarted due to a crank position sensor, that would be a cam position sensor, two very different parts.
Oct 04, 2012 | Cars & Trucks
I was on Facebook and my vio freezed for like more than two hours!! what should I do to retart without unplugging it?
Hold the power on button for about 10 seconds. If this does not work then the only option remaining is to unplug the mains power and remove the battery.
May 25, 2011 | Sony Computers & Internet
I replaced the timing chain in a 2005 potiac sunfire with a 2.2 and now it run rough but runs fin going down the road but idling it run rough and sometimes will die
if the car ran fine befor you changed the timing chain you may have the cam timing off by one tooth retarted. Being the PCM controls the timing advance . The engine smooths out at higher speeds .Start back tracking and looking at the simple stuff . but you may have to pull the timing housing again to check the timing marks on the cam and the crank
Mar 06, 2011 | 2002 Pontiac Sunfire
Overheats ive tried the obvious solutions and it still overheats any suggestions
note if it overheats on the freeway or in city driving. If it overheats soon after you leave the house then in has to be the thermostat. If it overheats at city driving where there are lots of stop and go driving or while you are parked with the motor running, then check the radiator fan function properly. If it takes a while to overheat and tend to do it when driving on the freeway, it is a clogged/dirty radiator. If it looses coolant due to a leak, then it will also overheat. The least likely cause which don't even pertain to newer car is a retarted timing. A retarted timing causes a car to loose noticable loose of power accompanied by overheating. A retartded timing is usually common in older car where timing is adjustable by turning the distributor. Your car is exempt from this.
Dec 27, 2009 | 2005 Chevrolet Equinox
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
Aug 31, 2009 | HP Pavilion A720N PC Desktop
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
Laptop keeps freezing
my laptop did this several times and i had to replace the motherboard 5 times, i suggest calling toshiba themselves
Jul 30, 2008 | Toshiba Satellite A135-S2276 Notebook
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
