Question about IBM (92P6581) for ThinkPad T40 (92P6581) CD-RW/DVD-ROM (Combo) Burner
Laptop boots up for 2 seconds and then goes to a black screen
I am having problems with my laptop (IBM T40,
My problem:
As soon as i hit the power button, the laptop boots up with all the LED lights on except the cyclinder icon, which happens for 2 seconds and then the LED lights turn off and the LED battery icon and the LED power icon remain on. Throughout the boot up the screen remains black.
My theory:
I think my laptop cant respond to my harddrive which may be cause i downloaded and installed a program called "RAM DEF xtreme 2.71" which helps to clean up the RAM. When i started the program for the first time, it asked whether i'd like to defragment the RAM (i think). So i begun the defragment procedure and then as it was about to finish, the program froze and then i had to end the program (a prompt came up telling me the program froze and it informed to to click close), after that the laptop was working fine until after a few hours the laptop crashed with a blue screen. So i restarted it but then i got the black screen problem.
-Help A.S.A.P would be grateful
  • armghanz Jul 30, 2009
    ops, it not ment to be about a cd or dvd burner, just the laptop itself
    thanks alot, just fixed it now, much appreciated pal
  • 89 Answers
Just remove your ram if u can and wipe it with the clean cloth and insert it again so that the bios mite reset... or you have to change the jumper on the mother board which you have to take to an technician and get it done...
Posted on Jul 30, 2009
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
My IBM Thinkpad T40 2723 will not boot up
The first thing to try is to unplug the power adapter from the computer then remove the battery. Then press down the power on button for a second or two. Put the battery back in and reconnect the power adapter and see if it boots.
Mar 26, 2009 | IBM ThinkPad T40 2373 Notebook
How to fix Error 0189
This worked for me on a R40 with the 0189 issue.
When the message pops up, hit escape to continue.
1. Download the IBM Hardware Maintenance Disk and create a floppy. The filename for version 1.75 is i7tm23us.exe. I found it at ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/i7tm23us.exe
2. If you do not have a floppy drive on your laptop, then use nero to create a bootable CD from the files and boot sector of the floppy disk.
3. Boot your laptop from the CD, then choose the Assign UUID option.
This should do the trick for you.
Jan 18, 2009 | IBM ThinkPad T40 2373 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
Ibm t40
Yap actually i greet you first
what your system is prompting you is that your Processor is getting Bad and you will need to replace it with a new ones ok
After that your system come back to life .
thanks
Rate this solution
Oct 20, 2008 | IBM ThinkPad T40 2373 Notebook
Toshiba screen wont turn on
Ok folks, not to sure if anyone is following this, However, I posted a problem a week or so ago, and this is an update to that problem. in Regards to my Toshiba M35x-S161 problem with the screen not coming on nor booting up. This is an update and may not be the same for all of you concerned.
I have checked the ram memory and found that to be working, and as mentioned was able to access the hard drive using a caddy to see that it is intact. However, shortly after doing so (I had copied pictures to a thumb nail for my sister), I began to experience a slowdown on my IBM laptop. It suddenly hit me, VIRUS. I scanned the IBM through Housecall, and what ever was affecting it caused house call to shut down 3 times, but did finally clean it. I pulled the Toshiba's hard drive stuck it into the Caddy and ran a scan on it using AVG and yet another IBM that is clean. After a slow scan there it was, not 1, not 2, but 3 Trojan virus plus 2 down loaders and a few other goodies. With the now cleaned Hard drive, I tried booting the Toshiba, and at first I still experienced the same problem, then a funny thing happened. I laid the laptop down an hit the side of it and poof here came the boot up. Unfortunately, it wouldn't go all the way, but enough to tell me that 'MOST LIKELY' the Virus halted the computer operation but killing the boot sector, and secondly, because it was stalled out in the boot up, it over heated, and "may have" loosened a solder connection on or near the switch or the power connector. I haven't had the time to take the unit apart yet, but plan to as soon as I can get a couple of days off.
I don't know how many of you this may help out, but at least this forum gives me a place to post my progress... will keep you updated as I can..
Dec 21, 2007 | Toshiba (K000002020) Motherboard
My Ibm t49 the display shuts off as soon i as i boot up help
There are several possibilities within two categories:
SOFTWARE (you are using MS, so this is more likely)
HARDWARE these symptoms can be caused by bad battery and/or bad PSU (AC Power Supply Unit)
Software: You may have a virus, or may have damaged the NT kernel, or some critical software components by installing cheap games or bad SW. Read the recovery instructions on your XP CD to boot and run recovery and/or utilities that might repair the laptop OS. If you have no CD, try booting and hitting F6 key after BIOS screen... then explore the options there. Next, try booting and hitting F8 key after BIOS screen... then explore the options there.
If there are no problems repaired or evident in software, you should remove the battery, plug in the PSU and try booting. If all goes well, your battery is probably bad. If NOTHING happens, then your PSU is definitely bad (or the PSU cable/jack/connection to your computer is bad)
Conversely, remove the PSU and boot only with the battery. If it boots up (or goes farther than it did before) then the battery may be low/damaged BECAUSE the PSU is bad. If your laptop does not even open/get at least to BIOS screen, then the battery is dead. Try recharging overnight with laptop off but plugged into AC. If it is the same in the morning, replace the battery.
Both the battery and PSU can be checked with a VTVM, to compare voltage/output levels, with the ratings on the labels
Dec 06, 2007 | IBM ThinkPad T40 2373 Notebook
IBM (92P6581) for ThinkPad T40 (92P6581) CD-RW/DVD-ROM (Combo) Burner Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
