Question about Acer Office Equipment & Supplies
My injet Stylus D92 needs new cartridge's, I can place the carrie
My injet Stylus D92 needs new cartridge's, I can not position the carrier in order to extract the old cartridge, what is the correct way to remove a cartridge. I did click to carry on printing, allowing the printer to make up a mix for the black, do I have to wait for all the other colours to run out.
I have solved the problem, a telephone call to the computer shop that supplied the printer.The printer button (the quick route) did not work. So I was talked through the control panel route.Just in case anyone else has this problem,here is the route,(I know everyone else out there already knows) but just in case!!-- Control Panel,click Printers.(&Faxes) right click your make of printer.click Properties. click printing Preferences. click maintenance.(at top). click replacement.
Posted on Jul 31, 2009
Please give us step by step instruction on how to change ink cartridge?
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • Mar 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    How do I change the ink cartridges?
    Step 1:Purchase an ink cartridge made specifically for your printer. Step 2:Turn on your printer and raise the lid or press the cartridge changing button. Step 3:Wait for the cartridge carrier to slide out. Step 4:Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Step 5:Carefully remove the tape from the ink opening on the bottom of new cartridge. Step 6:Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Step 7:Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Step 8:If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge. Step 9:Close printer cover.
    Jun 13, 2010 | Epson Stylus C86 InkJet Printer
    How do i change ink cartridge
    While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    Need to change the ink cartridge
  • Step 1
  • Step 8 Close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Feb 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    How do i put new ink cartridges into epson d92
    Hi Freind You Can go to the link I am pasting which will guide you to change your Ink Cartridges
    http://support.epson-europe.com/onlineguides/en/d92/html/ink_4.htm
    FTB
    Nov 22, 2009 | Epson Stylus D92 InkJet Photo Printer
    I get a message saying ink cartridges cannot be recognised
    make sure you are using the correct type of ink cartridges, then remove the ink cartridge, make sure they have ink on them. If they are new, remove any plastic covering on them. try to shake the ink a bit. with the printer turned off, unplug it from the power outlet, pres the power button for about 5 to 10 seconds to fully discharge residual power, install the cartridges making sure they are securely in place, plug the printer again and try printing again.
    Oct 27, 2009 | Epson Stylus D92 InkJet Photo Printer
    The ink cartridge carrier does not return to the opening in order to replenish the cartridges
    turn power off an then on as soon as the carriage starts to move out of home mode turn power off at wall. You can then manually move the carriage out to change the cartridge. Move it back to where it was when you moved it. Restart power and let it return to home.
    Please rate the help++++Thanks for using FIXYA
    Oct 09, 2009 | Epson Stylus D92 InkJet Photo Printer
    How do i change the black ink cartridge on a lexmark x2580 printer
    With printer on and connected to computer do the following:
    Open top cover.
    Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
    Wait for ink carriage for taking position in the middle of the printer rail.
    Open cartridge top cover.
    Pull cartridge toward yourself and snap it out.
    Do the same in reverse order to fit new cartridge.
    Remember to remove cello tape strip from new cartridge nozzle.
    Do alignment procedure after replacement.
    Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
    I need to change the ink cartridge for my epson rx500.
    If you'd like to view the instructions on how to replace the cartridge in HTML (web page, non PDF) format that you don't have to download, click here.
    It is directly from HP with photos on how to do this. If you need anything else, just ask. :)
    Apr 08, 2009 | Epson Stylus RX500 All-In-One InkJet...
    I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
    buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
    Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Top Acer Office Equipment & Supplies Experts
    jasbo
    jasbo
    color wheel light...
    Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
