Question about Maytag Washing Machines
Knob just goes around will work
Control knob just goes around, and will not catch on a setting .
    Scholar:
  • 97 Answers
Sounds to me like one of two problems. Either you need a new knob, or more than likely need a new timer switch that mounts behind the knob.
Posted on Jul 30, 2009
How to set gas control knob on 18,000btu empire heater its out of whack
CORGI used to be the registered engineers for GAS appliances, but this has now been superceeded by 'GAS SAFE' contact any GAS SAFE engineer.
Oct 08, 2014 | Empire Comfort Systems SR-18LP 18,000 BTU...
Volume knob on dell ac511 soundddddddbar just goes around and around. should it click on or off
Yes it should just go around and around. If the correct drivers are installed, it will work with the volume controls and display on the PC
Jan 03, 2014 | Dell AS500 Sound Bar Computer Speakers
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
I am replacing my door knob and replacing it with similar lock door knob by Kwikset. I measured from the end of the door to the middle of the hole where the knob goes into which is 2 3/8". The problem...
Most kwikset locksets will work on either 2 3/8 or 2 3/4 inch setback. There should be two holes on the latch where door knobs fit thru the door. If yours does not have this option I would suggest that you get one that will match your setback.Hope this helps.Thanks.
Nov 16, 2010 | Garden
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
We have a 2005 ford focus wagon and the locking mechanism on the door will not unlatch which means we cannot close the door. Is there a way to fix this myself?
Have a look at the catch on the door.It has a 'forked' piece that swings one way or the other.On the car,there is a small 'knob' that sticks out about 1/2 inch.With a thick bladed screwdriver,the catch on the door must be clicked back into position so the opening of the fork can let the 'knob' slide into the catch.When looking at the catch,the moving fork is mounted in the catch itself so push around the screwdriver to flick it back out.Its a hard thing to describe but once you do it you will see what I mean.Hope this helps you(the fork has to be swung/clicked sideways)
Jan 02, 2010 | 2005 Ford Focus
Cycle control GE WHDSR315 top loading washer.
Try pulling the knobs off completely and squirting WD-40 into the switch interior--work the oil in by reinstalling the knobs and moving them around. If no help, then the area behind the control panel must be accessed (pull the power plug), and the control replaced (you should have seen the mounting screws when the knobs were off).
Oct 11, 2009 | Washing Machines
The door knob (lever door knob to exterior fancy door) came off.
When you first tightened the screws, the mechanism may have been loose enough to allow the actuator bar the connects the inside knob to the outside lever to work loose. When you tightened it you may have jambed that tight so things didn't work. When you disassembled everything, you may have lost that part. The springs are usually integrated into the catch part and are not removeable. Sometimes it helps to take everything completely off the door including the catch that goes in the edge of the door. Then reassemble it on a table to see what works and what doesn't. If that doesn't help, take all the pieces into Lowes at the key desk and they will be glad to help you.
Jun 18, 2009 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Settings unreadable around all control knobs
Found suitable picture on TradeMe so down loaded and edited to suit my purpose
Mar 22, 2009 | Washing Machines
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
