Question about Coleman Mach III Air Conditioner
Motor home AC not cooling
The AC in my motor home sounds good, blows well, seems to be trying to "kick in" when switched from "fan only" to "cooling" but the air is no cooler when on "cooling" than on "fan only." I checked from below in the motor home and above from on the roof, and could not find any access points (valves or service points) in order to "charge" the system. It acts just like a car AC system that is low on "freon." Is there a way to "charge" the system? Is it possible to put "valves" or "service points" somewhere in the line in order to recharge the system? Does my rooftop system use "freon" like the AC in the engine of the motor home or does it use a different chemical? This is a 1993 29' Jayco motor home with the original basic rooftop unit. I would appreciate any help anyone may have. Thanks, Glendon Widrick
    Scholar:
  • 97 Answers
The only service ports that you are likely to find would be on the unit itself on the roof. I would imagine you'll probably have to open an axcess panel on the unit to get to these.
As far as what kind of refrigerant is in these usually that same axcess plate will tell you. I couldn't tell you right off hand but usually its r-410a or r-407c. Occasionally you'll find one with r-22 but again it's up to the manufacturer.
But before you decide to try adding refrigerant keep in mind that legally this should only be done by a qualified service person. Not to mention that there could be a host of electrical or mechanical causes for this. Adding freon is not always, and most typically never is, the problem.
Yes this could be caused by low freon but again, if that's the case then it is most likely leaking and will need to have the leak repaired. This could also be caused by, but not limited to:
- a bad thermostat
- a bad relay
- a bad compressor
- a malfunctioning expansion valve
In summary I would highly recommend not trying to do this one yourself without the proper tools. You may very well end up causing more damage than you solve.
Posted on Jul 30, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
I too have the same issue with the compressor noise
I am Ron,I will try and help,,what valve?It sounds like you need to check to see if the cooling fans are working,and working properly when ac is on.If it has two cooling fans ,are they both working?If not, find out why not(check fan relays and fan itself to see if it is good)also if the fan or fans are kicking in high speed after ac pressure exceeds 225psi.If I can help please ask,,,roniecon@gmail.com
Aug 04, 2009 | 2005 Chevrolet Equinox
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Goodman PGJ030075-1 Motor Not Spinning - No Cool Air Blowing
I assume you are talking about the evaporator fan motor. Check the capacitor. Replace if necessary. If cap shows good then it's most likely the indoor fan motor.
Jun 05, 2009 | Heating & Cooling
Not cooling just feels like the fan is on.
HEY, sounds like it time for a full clean-up. Take the cover off and clean the drain ports, the filter in the front of the unit, the back inside coils, oil the fan motor, wash the front coils, ,, The water blowing out could be because its not leanning back enough, & the coils or filter is plugged and trying to **** air anywhere it can ,even thru the drainnage system! Thank-you-very-much!
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
2005 Nissan Sentra, AC blowing hot & engine overheating
most likely a thermostat because the pressure on the a\c will be high if engine is over heating or the fans are not kicking on (check fan relay)
Aug 25, 2008 | 2005 Nissan Sentra
Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
May 18, 2008 | Maytag Heating & Cooling
Coleman Mach III Air Conditioner Logo
517 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
