first thing 1000@4 means 250w per ch. which means150w usable power.the mode switch is only to reduce rca cables,use 2ch mode if only 1 pair rca available,60hz is a bit low for this amp,90 would work better.
SOURCE: DHD AMP
How do you have it wired now?
Impedance of each voice coil?
Number of voice coils per speaker?
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
SOURCE: Help installing DHD 2114 amp to Impala 03 factory radio
What car are you looking for the wiring diagram for?
A simple line level converter would convert an input signal to a factory speaker - into a useable Low Level RCA signal for your amplifier.
There is your signal - now all you'll need from behind the radio is the 12V Remote signal.
Send me your make/model/year, and i will tell you which wire to use.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: need wiring diagram for bmw-483 1000w 4 channel amp bought used
left + goes to the amp left - goes to the + on the right sub and the right - goes to the amp try that
rate pls
